Oil pump drive gear ,2.5d
Postby chain13 » Wed Mar 11, 2026 9:16 pm
Hi there , i,m doing a front cover on my 1997 2.5d because it cracked the plate at the top from inj pump being loose , now when i pulled it down i noticed the oil pump drive has no woodruff key .it spins freely with no tension at all , i know the bolt holds it but shouldnt it be a press fit to start with ,do i need to use a bearing retainer loctite or is the gear just worn , cheers for any help
chain13
Re: Oil pump drive gear ,2.5d
Postby metalworker0 » Thu Mar 12, 2026 12:24 am
save this manual because .. they usually disappear after a while
page 105
https://www.marinedieselbasics.com/wp-c ... ervice.pdf
other than use a special hylomar pl32m sealent .. says nothing else
Postby chain13 » Thu Mar 12, 2026 4:31 am
thanks mark for reply , yeah i have found that manual but didnt know if there was a hidden trick to it , trust ford to make something without a key way . i could put some bearing retainer locktight on it but didnt know if this was good or bad idea . please if anyone else has a hidden trick let me know , cheers
chain13
Postby V184 » Thu Mar 12, 2026 4:28 pm
chain13 wrote:Hi there , i,m doing a front cover on my 1997 2.5d because it cracked the plate at the top from inj pump being loose , now when i pulled it down i noticed the oil pump drive has no woodruff key .it spins freely with no tension at all , i know the bolt holds it but shouldnt it be a press fit to start with ,do i need to use a bearing retainer loctite or is the gear just worn , cheers for any help
Just torque it up to spec not a press fit :wink:
V184
Postby metalworker0 » Thu Mar 12, 2026 4:55 pm
is it tapperd?
Postby MinorMatt » Mon Mar 16, 2026 12:08 pm
The gear is held solely by the clamping force of the crank pulley bolt. There is no woodruff key, no bearing fit or anything along those lines.
Its extremely rare that is causes any problems.
