1998 transit 2.5d with no banana intake manifold
Postby andyproc » Wed Mar 18, 2026 8:51 pm
Hi All,
I have a 1998 transit based Autosleeper Duetto campervan. It has a 2.5 naturally aspirated diesel engine but looks nothing like the "banana" intake manifold engine that I am led to believe would be correct for that period.
I have some mechanical knowledge and have owned and run diesels for many years but am a newbie on this club site and would be grateful for any information to solve my little puzzle.
Andy :roll:
andyproc
Re: 1998 transit 2.5d with no banana intake manifold
Postby Mislaid » Thu Mar 19, 2026 2:01 pm
Check code on engine block, then you can crosscheck and confirm age and flavour of your engine
First list to hand....
Ford Transit Engine Codes
Below is a comprehensive list of Ford Transit engine codes for vans built between 1986 and 2014. If you cannot see your engine listed or are unsure which code matches your van engine please call us on 01753 208 222
Make Model Engine CC Engine code kW DIN hp rpm Tuned for Year Fuel Cylinders
Ford Transit 86 1.6 1600 LAT 46 62 4750 1986-91 Petrol 4/OHC
Ford Transit 86 1.6 1600 LAC 46 62 4750 1986-91 Petrol 4/OHC
Ford Transit 86 2.0 2000 NAT/W/X/V 57 77 4500 1986-91 Petrol 4/OHC
Ford Transit 86 2.0 2000 N6T 57 78 4900 R-Cat 1989-91 Petrol 4/OHC
Ford Transit 86 2.0 2000 N6TS 60 82 0 R-Cat 1986-91 Petrol 4/OHC
Ford Transit 86 2.5D Di 2500 4BA/4BB 52 70 4000 Bosch 1989-91 Diesel 4/OHV
Ford Transit 86 2.5D Di 2500 4CA/4CB 52 70 4000 RotoDiesel 1989-91 Diesel 4/OHV
Ford Transit 86 2.5D Di 2500 4CA 52 70 4000 Bosch 1989-91 Diesel 4/OHV
Ford Transit 86 2.5D Di 2500 4BB 52 70 4000 1989-91 Diesel 4/OHV
Ford Transit 86 2.9 2900 B4T 110 150 5700 1989-91 Petrol 6/OHV
Ford Transit 86 2.5 2500 4AB 50 68 4000 1986-88 Diesel 4/OHV
Ford Transit 92 2.0 2000 NBA 66 88 5000 1991-93 Petrol 4/OHC
Ford Transit 92 2.0 2000 NCA 72 98 5250 R-Cat 1991-95 Petrol 4/OHC
Ford Transit 92 2.5D Di 2500 4BC/4CC/4FA 51 70 4000 RotoDiesel 1991-94 Diesel 4/OHV
Ford Transit 92 2.5D Di 2500 4BC/4CC/4FA 52 70 4000 Bosch 1991-94 Diesel 4/OHV
Ford Transit 92 2.5D Di 2500 4DA 59 80 4000 RotoDiesel 1991-94 Diesel 4/OHV
Ford Transit 92 2.5D Di 2500 4DA 59 80 4000 Bosch 1991-94 Diesel 4/OHV
Ford Transit 92 2.5D Turbo 2500 4EA/EAB 74 100 4000 1991-94 Diesel 4/OHC
Ford Transit 92 2.5D Turbo 2500 4GA 63 85 4000 1991-94 Diesel 4/OHV
Ford Transit 92 2.9 2900 BRT 107 145 5500 R-Cat 1991-95 Petrol 6/OHV
Ford Transit 95 2.0 2000 NSF/NSG 84 114 5000 R-Cat 1994-00 Petrol 4/DOHC
Ford Transit 95 2.0 2000 NSH 84 114 5000 R-Cat 1998-00 Petrol 4/DOHC
Ford Transit 95 2.5D 2500 4FA/FB/FC 51 70 4000 1995-00 Diesel 4/OHV
Ford Transit 95 2.5D 2500 4HB 56 76 4000 1995-00 Diesel 4/OHV
Ford Transit 95 2.5D 2500 4FD 51 70 4000 1994-00 Diesel 4/OHV
Ford Transit 95 2.5D 2500 4HC 56 76 4000 1994-00 Diesel 4/OHV
Ford Transit 95 2.5D TCI 2500 4ED 85 115 4000 1997-00 Diesel 4/OHV
Ford Transit 95 2.5D Turbo 2500 4GA/GB/GC/GD 63 85 4000 1995-00 Diesel 4/OHV
Ford Transit 95 2.5D Turbo 2500 4GE/GF 63 85 4000 1994-00 Diesel 4/OHV
Ford Transit 95 2.5D Turbo 2500 4EC 74 100 4000 1994-00 Diesel 4/OHV
Ford Transit 95 2.5D Turbo 2500 4HD 55 75 4000 1998-00 Diesel 4/OHV
Ford Transit 95 2.5D Turbo 2500 4HA 55 75 4000 1998-00 Diesel 4/OHV
Ford Transit 95 2.5D Turbo 2500 4EB 74 100 4000 1995-00 Diesel 4/OHV
Mislaid
Postby MinorMatt » Thu Mar 19, 2026 3:23 pm
Duettos were fitted with either a 76PS Non Turbo DI engine, or the 85PS 2.5TD engine
If its not a turbo, and doesn't have the "bananna" manifold, its had a 70PS engine fitted. Exactly the same in every respect except the injectors, the "mapping" on the injection pump and the manifolds.
Don't be too upset about the loss of 6PS - it really makes no difference at all.
Are you 100% certain its not a turbo engine? The turbo is well hidden below the exhaust manifold and by the air box
If you want confirmation - take a pic and post it up?
Postby metalworker0 » Tue Mar 24, 2026 5:50 pm
only goes to 1995 mate .. i ask .. as there is a poster in this thread asking about codes, perhaps you can help him.
viewtopic.php?f=2&t=236532
a
