Banana engine coolant leak after new water pump
Postby circitfied » Tue Apr 07, 2026 5:30 pm
Hi,
I have a 1999 for transit bus, fitted with a 2.5 banana engine. Noticed a coolant leak at the back of the water pump, so I changed the water pump and timing belt. However, I still have a coolant leak. I think it is from the flange pictured. Is this likely and how do you even replace the seal?
Water seams to deep from the area at high revs.
Thanks in advance and apologies for the terrible post.
circitfied
Re: Banana engine coolant leak after new water pump
Postby metalworker0 » Tue Apr 07, 2026 8:57 pm
well here's what you have as far as gaskets .. as far as i can help
http://www.catcar.info/ford/?lang=en&l= ... g3MDQrMjcy
Postby circitfied » Tue Apr 07, 2026 9:56 pm
Cheers,
I installed a new gasket too. I'm pretty sure the leak is on the other side of the engine block, where the exit pipe is. It's an absolute pig to access.
circitfied
Postby metalworker0 » Tue Apr 07, 2026 10:01 pm
http://www.catcar.info/ford/?lang=en&l= ... A5NDQrMjcy
more
some seals there .. but not in the parts list
