ford transit mk4 voltage regulator (clocks)
Postby Sillywabbit1233 » Sat Apr 11, 2026 5:59 pm
Hi everyone was wondering if anyone knew the part number or the voltage regulator number for the dash gauge mine has a hole through the numbers and cant get the number of it.
Sillywabbit1233
Re: ford transit mk4 voltage regulator (clocks)
Postby robbie.cee » Sun Apr 12, 2026 6:53 pm
I found it on here some years bavk when i fixed my pals dash, temp and fuel gauge..
Ill try and find it...
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sun Apr 12, 2026 7:21 pm
https://ebay.us/m/55HpeC
Should be sufficient
Had
MAKE IT FIT
robbie.cee
Postby Sillywabbit1233 » Mon Apr 13, 2026 9:00 am
Thank you will buy today.
Sillywabbit1233
Postby Sillywabbit1233 » Mon Apr 13, 2026 10:33 pm
So that did not fix the dash clocks not working its relieving voltage but does not move jumped the blug on the sending unit for fuel and needle does not move would you say the dash has blown?
Sillywabbit1233
Postby robbie.cee » Tue Apr 14, 2026 8:28 am
That or earth loop broken,
Temp is earth to sensor and return to dial
Fuel is earth to sender and return to dial.
Check also dash earth think under steering column poss 2 brown wires on same terminal bolted to body
Had
MAKE IT FIT
robbie.cee
