Maybe your fuel lift pump is failing. Located on the bottom right on the engine block. Usually behind a small heat shield. (While facing the engine) below the exhaust manifold. A round disc like device with fuel lines in and out. Check that the bolts are still tight. Known to wiggle their way loose over time. Maybe someone here can suggest a way to test it (like maybe opening up the fuel filter inlet to see what if fuel comes out while cranking?)Viva_65 wrote:Hello thankyou for the replys,
its. in a mk1 ford transit, its the 2.5 di engine but not sure of the year pump.number 0460 424 086
I.managed to cable tie it back but idle is rough understandably, until i can get a more perminant solution
I managed to get it to the festival, but every 15 minutes same symptoms of fuel starvation, when it does it i go straight to crack the injectors and there is air in everyone, im pretty sure my fuel filter is emptying and then drawing air, its a pain to bleed everytime using the fuel filter housing screw on top.
Viva_65 wrote:Yeah thats the ones im thinking those pipes yeah, i would like to run a clear hose so i can see if any air comes in, think i will swap out the pipe for rubber, leave that one in place and try that, well first thos cold start lever
