Idle control search MK3 - support requested
Postby BerlinTransit » Tue Jun 09, 2026 8:39 pm
Electronic idle control // Leerlaufregeler shot — no replacement found — photo attached.
We have diagnosed a high idle RPM to this piece, which we plus a local mechanic cannot find. The removed piece had no serial number, and other sites refer to idle controls with valves that aren’t a fit. Had anyone seen this before and know where a replacement could be found? Is it even original? Any help is appreciated.
My partner and I in Berlin bought a beautiful blue transit camper in 2024. 1989 MK3 - I believe 2.0 57kw version.
BerlinTransit
Re: Idle control search MK3 - support requested
Postby metalworker0 » Tue Jun 09, 2026 9:44 pm
i trust that yours is the CFI version .. centralised fuel injection
if ive got this right its called a "actuator assembly throttle control" part number 6162378
there are 2 new on UK ebay and one used on German ebay
USED German one ... note it fits other cars
https://www.ebay.co.uk/itm/137287746731?
NEW UK ebay
https://www.ebay.co.uk/itm/389978065581?
https://www.ebay.co.uk/itm/376191541707?
there is more info on part numbers here
http://www.catcar.info/ford/?lang=en&l= ... Q4NDgrMjY0
NOTE : all do not come with the bracket / mounting components
Postby BerlinTransit » Tue Jun 09, 2026 10:43 pm
Mark,
This is very helpful and might be the solution. Any way to confirm the motor match? Here’s anything photo but maybe there’s more details on our model that could verify. Thanks again!
BerlinTransit
Postby metalworker0 » Tue Jun 09, 2026 11:14 pm
That pics no good for me .. its all up top -- no detail, not helpful.
Its what we call here a pinto engine .. if valve cover looks like so
http://www.catcar.info/ford/?lang=en&l= ... NCsyNjQ%3D
Think just by ID-ing the component .. ive established its a 2.0 pinto with CFI injection, engine link known on that site as OHC TL LL
here's the main page
The engine was common at the time, was in lots of cars before 1989 capri's, escort's, granada's, scorpio, cortina's, Taunus in Germany, sierra, most of these had carbs .. there were CFI single point versions, EFI multipoint versions and LPG.
