Antifreeze 1997 Mk 5 Diesel
Postby Nic1234 » Sat Sep 05, 2026 4:32 pm
Hello, I’ve only owned this van a couple of years and I know the coolant was flushed and replaced at that time with pink antifreeze. I’ve been advised that “any red product will do” to top up but I’m hopeful someone will be able to advise what is recommended. Thanks in anticipation
Nic1234
Re: Antifreeze 1997 Mk 5 Diesel
Postby metalworker0 » Sat Sep 05, 2026 5:26 pm
The fords older orangey pink stuff is called POAT - Phosphated Organic Acid Technology-- if you want to look it up
So long as the new one has poat or p-oat written on it .. it's ok
Ford have gone to a newer 10 year one, that is mixable with the old stuff .. Prestone also make it .. and call it ten year antifreeeze .. and is a lemon yellow in color, Prestone claim its compatible with all antifreeze and mixes with all colours.
Bit confusing .. yes .. you can do your own research to confirm what i said .. this knowledge is fresh from when i did the research a couple of days ago.
Antifreezes are available in concentrated versions or ready mixed .. in the UK you dilute the concentrated to:
2 of water 1 of antifreeze .. 30 percent
Postby Nic1234 » Sat Sep 05, 2026 8:34 pm
Many thanks Mark, very helpful. Best regards, Nick
Nic1234
Postby dumper » Mon Sep 07, 2026 8:28 am
The last time i checked Ford filed them from new at 50% that’s what we mixed it at work the only time they it got changed was when the water system had a repair or a leak every inspection it was checked and topped up to 50% if needed
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Nic1234 » Mon Sep 07, 2026 9:04 am
Thank you Dumper
Nic1234
