A4LDe gearbox
A4LDe gearbox
Postby smartie » Sun Feb 24, 2008 10:12 am
Tec quest..99 2.5Di VG with A4LDe auto gearbox. Can any one help!
Under medium load the overdrive slips, seams like the torque converter lockup clutch unlocks.
smartie
Re: A4LDe gearbox
Postby davydave » Sun Feb 24, 2008 11:15 am
Sounds like the brake bands need to be adjusted.My old Granada did the same trick.Cant remember how much it cost to get done,but its not a lot.
Day van,Camper van!
davydave
Re: A4LDe gearbox
Postby smartie » Sun Feb 24, 2008 11:37 am
Just had the gearbox serviced!
smartie
Re: A4LDe gearbox
Postby AndyG » Sun Feb 24, 2008 8:23 pm
Did they know that they had to check/adjust the two bands as well :?:
Did they change the oil and filter and what type of ATF oil did they use :?:
If you haven't left it too late/allowed the box to slip continually :shock: :(
You can do a modification that will cure your problem :!: :D
:idea: Might be worth a go anyway :!:
Andyg wrote:
Taken from here
viewtopic.php?f=5&t=11204&start=0&st=0&sk=t&sd=a&hilit=modification+transmission
Andyg wrote:
The cure is so simple that Ford ought to be ashamed of themselves for not informing the very few automatic owners there are about it. (too late once it's burnt out :roll: )
1x servo piston and cover :D
A ten minute job that can be carried out easily without any major dismantling :roll: :x
Finis codes; 1 024 140 and 1 023 674
Re: A4LDe gearbox
Postby smartie » Wed Feb 27, 2008 7:24 am
Thankyou for the info!
Could you expand on the mod you mention.
Regards
Smartie
smartie
Re: A4LDe gearbox
Postby AndyG » Fri Feb 29, 2008 1:47 am
It'll be easier for you to understand, when you have the bits in your hand :!:
On the drivers side of the transmission, you will see two round, similar looking "plugs" :!:
Give this area a thorough clean, as you don't want to get any kind of dirt into the transmission :!: :!: :!:
Look carefully at the right hand one (the one closest to the engine) :!:
You will see a circular spring clip/circlip holding it in :!:
Using a small screwdriver, you can unlock it from it's groove (you may have to push the cover in, to assist you, as there is a spring pushing it outwards :!:
Once this is off, the cover may pop out with the servo and a coiled spring, or you may have to help it, by twisting it to help it pop out as the oil seal may be giving some resistance :!: (you'll know what I mean)
You will loose a little bit of oil at this stage :!:
Now simply fit the new servo and cover in it's place, not forgetting the spring and lubing up the seals with some transmission oil :!:
Refit circlip making sure it has seated fully :!:
Job done :!: :wink:
This new servo will give the extra pressure required to stop the slipping, providing that;
a) The band has been adjusted correctly :!:
b) The band hasn't worn out already :!:
Re: A4LDe gearbox
Postby smartie » Mon Mar 10, 2008 3:52 am
Thank you for the info!
Our local ford dealer in Australia has not heard of FINIS CODE, he can not help with the parts that are required, is there some one in UK that I can aquire the parts.
I have spoken to two other Transit owners with auto box and they have been told by their Ford dealers to use their vans as cubby houses for the kids.
smartie
Re: A4LDe gearbox
Postby AndyG » Mon Mar 10, 2008 11:42 am
Ok, I am surprised the dealer can't simply enter those numbers into his commy :roll:
Never mind :D just gone and dug out the boxes the parts came in :!:
Part Description: PISTON AND ROD
FINIS CODE: 1024140
97GT 7E221 ZA
C18121
A3 (WP)
Part Description: COVER
FINIS CODE: 1023674
97GT7L493ZC
C24906
B3 (WP)
Hope this helps :!: :D
Re: A4LDe gearbox
Postby bill99 » Tue Mar 11, 2008 12:59 am
Does anyone know what year the auto box changed from A4LD to the “e” version A4LDe?
Just wondering, I have a 1996 Transit 150 Auto Turbo so just thinking ahead and wondering if mine will be the “e” version and could benefit from this servo modification.
Andyg, would there be any external way to tell if the servo mod has been done already just by close inspection.
bill
bill99
Re: A4LDe gearbox
Postby AndyG » Tue Mar 11, 2008 1:22 am
The A4lde was fitted from late 1994 model year, also known as "Transit '95" and referred to on this forum and elsewhere as the "Smiley" or "MK5" :D
You can tell if you have the modified one on your transmission by the letters ZC stamped in the cover and you can see that the cover has a larger protruding diameter compared to the standard one, or compared to the 2nd gear servo :!:
When the weather improves, I'll get underneath and take a piccy or I might even just order another set and compare with the pair I've already removed :!:
Not that expensive from memory, so I'll post back on this with UK prices and picces :!: :wink:
Re: A4LDe gearbox
Postby smartie » Thu Mar 27, 2008 12:48 pm
I am Back!!!!
Thank you for your help!
I have made several enquires to Ford dealers about the FINIS code and the part numbers that you supplied, they have come to the conclusion that the numbers only apply to the UK.
Is there any parts suppliers in the UK that mail order via the internet?
Regards
SMARTIE
smartie
Re: A4LDe gearbox
Postby AndyG » Fri Mar 28, 2008 1:09 am
97GT 7E221 ZA
C18121
A3 (WP)
97GT7L493ZC
C24906
B3 (WP)
How about the 97GT................ numbers :?:
The parts required are standard on the FORD EXPLORER 1992 TO 2000 and the FORD RANGER 2002 onwards if that's any help :?: :D
Re: A4LDe gearbox
Postby AndyG » Mon May 12, 2008 4:34 pm
bill
Now the weather has finally improved and we seem to have longer daylight :!: :D :D
Here are the differences between the two servo covers :!:
As you can see by the arrows, the modified one has a broader flat shoulder :!: (compared)
And here's a photo or two of how it looks before fitting :!: :D
Note the letters ZC on the cover
:idea: I might even consider this for the other band :o
Re: A4LDe gearbox
Postby bill99 » Fri May 16, 2008 10:20 pm
Ah thanks for the pics, yep i still have the old servo cover plate.
Guess i need to get onto this now the weathers here.
cheers
bill
bill99
Re: A4LDe gearbox
Postby Captain Beardy » Sat May 17, 2008 11:36 pm
'Ello, Andy ,..
Are the servo mods the same for the earlier A4LD ?
( Same part numbers etc ? ).
www.myspace.com/opustide
... OPUS TIDE's debut album , ' OPEN THE GATES ' available soon,....
.... BUY - IT !..... It's the LAW,......
Captain Beardy
