Transit front nbrakes
Postby TBH » Tue Apr 08, 2008 9:29 pm
I have a 1998 Transit (smiley) and the MOT has advised new front disc pads Can you advise the necessary torque settings for the calipers and discs? Thanks TBH
TBH
Re: Transit front nbrakes
Postby sportscott » Tue Apr 08, 2008 10:29 pm
I've only ever done the calipers up tight as for the torque setting for the discs :? they are not bolted on.
And welcome :wink:
Transit the everyday mans van....
sportscott
Postby MrMPuk » Tue Apr 08, 2008 10:31 pm
sportscott wrote:as for the torque setting for the discs :? they are not bolted on.
I think you'll find they are!
Postby rover » Tue Apr 08, 2008 10:35 pm
Do the bolts up tight with a 3/8ths ratchet and bend the locking tabs back into place, simple as that really.
Rover.
rover
Postby transitexpress » Tue Apr 08, 2008 10:54 pm
Welcome to The Forum. :D
Old transits need never die just keep mending em!
transitexpress
Postby Guy88 » Tue Apr 08, 2008 11:02 pm
disc retaining bolts are 50Nm
Caliper carrier to hub assembly is105Nm
Caliper to carrier torx bolts are 25Nm
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby sportscott » Wed Apr 09, 2008 7:41 am
Your right, could'nt sleep all night thinking about it,
They're bolted on from the back with a retaining plate, one for three bolts and the other for two :oops: :oops:
sportscott
Postby TBH » Wed Apr 09, 2008 9:18 am
:P Many thanks for welcome messages and for the info. Looking at the disc there are five bolts on the front. I am hoping that these are the retaining bolts!!! TBH
TBH
Postby rover » Wed Apr 09, 2008 9:21 am
TBH wrote::P . Looking at the disc there are five bolts on the front. I am hoping that these are the retaining bolts!!! TBH
They are mate :wink:
Rover.
rover
Postby sportscott » Wed Apr 09, 2008 5:00 pm
TBH wrote::P Many thanks for welcome messages and for the info. Looking at the disc there are five bolts on the front. I am hoping that these are the retaining bolts!!! TBH
Oh dear :oops: :oops: :oops:
Just make sure you've got a decent hammer and a bit of plywood or similar to put under the hub assembly to evenly beat around the disc to get it off, if your going not to use the old discs that is..
sportscott
Postby WINDSCREENGUY » Wed Apr 09, 2008 6:43 pm
why not just do them up really tight i always do all bolts like that, althought ive sheared a few off before :roll:
formally grey van man.
2010 115 semi high mwb . Fully loaded.
WINDSCREENGUY
previously grey van man
Postby sportscott » Wed Apr 09, 2008 8:01 pm
Disc to mounting bell Tightening Torque 14.0Nm (10.5 lbs ft).
And a whole lot more calories with the hammer to get off :lol:
sportscott
Postby Guy88 » Wed Apr 09, 2008 8:20 pm
Remove the 5 bolts from the disc and then beat it off befor removing the hub :wink:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby chris13 » Wed Apr 09, 2008 8:42 pm
I would just like to know if the discs are past there best and your advised to change them too because its not necessary to change discs with new pads. To do just pads its (I think) 45 torxs on the caliper flip down and replace if it wont undo its (I think) 19mm bolts to remove caliper from the hub.
chris13
Postby sportscott » Wed Apr 09, 2008 10:11 pm
I though that 12mm disc thickness was minimal and of course if badly worn would be a reason to change them.
sportscott
