Split charging
Split charging
Postby spondootre » Mon Dec 19, 2005 11:10 pm
Hi,
I'm going to be adding some extra audio equipment and some fancy lights etc to my K reg petrol Van. I am pretty sure that the current set up is not going to support it!! (The lights dim when the heater fan is on etc!) so I am after some advice on what to do.
do you think that split charging with an extra battery would be enough? And why do I need a split charging relay? Can't I just parallel the 2 batteries?
Is there anything else I can do to increase the power? Is there an upgrade for the alternator?
any advice is welcome!!
Cheers
Malc
spondootre
Postby FredTransit » Mon Dec 19, 2005 11:13 pm
What transit is this? Petrol or diesel? Two batteries and a higher output alternator are a Special Vehicle Option (SVO) from ford, so it's easy enough to fit, two of ours have it and they are just interlinked batteries, no split charger.
FredTransit
Mk2 Trannyist
Postby spondootre » Mon Dec 19, 2005 11:18 pm
It's a 1994 K reg Petrol Transit. Do you know if one's available for this one? Are they expensive?
Cheers
Malc
spondootre
Postby FredTransit » Mon Dec 19, 2005 11:26 pm
Theoretically they can be fitted to a petrol engine, one of ours is on a V6 ambulance. Both were there when we got the vans, so have no idea of the cost. See if you can find an ambulance in a scrappy.
Edit - forgot to mention the amby has god knows what fitted to it (for internal and external lighting and equipment), and though is all original the electrics are just a bunch of complicated spaghetti to me! Actual wiring is not my strong point....... the diesel SVO had a lot of the electrics replaced when we got her, as she was literally a shed before that. That's how I know there is no split charger on that one, but I don't know if it's better that way due to being a diesel (and therefore using less electric power to run) or just comvenient to fit like that.
FredTransit
Mk2 Trannyist
Postby Luke » Mon Dec 19, 2005 11:30 pm
out of interest i have twin batterys on my mk3 shed [2.0 pinto swb 80 1991] they look like they are factory as the wires go into the loom!
but only one has a thick starter wire - is this how it should be?
:D
Postby spondootre » Mon Dec 19, 2005 11:35 pm
I might phone fords and ask the question on how much........then after i've picked myself up off the floor and reset the phone i'll go the scrappy and have a look!!
Where would the other battery go? under the drives seat? If I can't find an upgrade that'll go I suppose I could go down the split charging route.
Cheers
Malc
spondootre
Postby Luke » Mon Dec 19, 2005 11:37 pm
spondootre wrote:Where would the other battery go? under the drives seat?
mine is in the same place as the existing battery but at the other side!! :D
Postby FredTransit » Mon Dec 19, 2005 11:37 pm
spondootre wrote:I might phone fords and ask the question on how much........then after i've picked myself up off the floor and reset the phone i'll go the scrappy and have a look!!
Cheers
Malc
Both of ours are Mk2, so there is more room under the bonnet and there is a battery each side, on it's own fitted battery tray.
FredTransit
Mk2 Trannyist
Postby spondootre » Mon Dec 19, 2005 11:46 pm
there should be enough room under the bonnet for it then, i'll have alook in the light tomorrow. I don't know the output of the alternator but am I right in thinking it's the same engine as a sierra of the same year? If so I suppose I could look at upgrades for that. I could also invest in the haynes manual for it!! I have a manual for a diesel Mk3 but they didn't make one for the petrol so i'm stumped on engine specs.
Cheers
Malc
spondootre
Postby MrMPuk » Mon Dec 19, 2005 11:48 pm
If you buy another battery tray it will just bolt straight in, only thing is i'm not sure if they are handed!
Postby Luke » Mon Dec 19, 2005 11:49 pm
MrMPuk wrote:If you buy another battery tray it will just bolt straight in, only thing is i'm not sure if they are handed!
i'll have a look at mine! i'll be taking one out i cant afford to run 2 batterys!! :lol:
Postby FredTransit » Mon Dec 19, 2005 11:54 pm
I think they are handed, try ordering either an SVO 2nd battery tray, or one for the LHD
FredTransit
Mk2 Trannyist
Postby MrMPuk » Mon Dec 19, 2005 11:58 pm
Looking at the pictures Luke just sent me they look handed! So as Fred says try and order a left hand drive one.
Postby Luke » Tue Dec 20, 2005 12:01 am
Here is a piccy of each one taken 5 mins ago!!!
:D
Postby Luke » Tue Dec 20, 2005 12:02 am
i keep my van in the house you see :wink: :lol:
