Mk4 Dashboard swap
Mk4 Dashboard swap
Postby Northfalia » Sun Nov 09, 2008 8:46 pm
Hi, have a K reg mk 4, and have been given a dash from an R reg smiley, I realise that the heater box is different, and the speedo is electric not cable, is there anything else to worry about? Has anyone out there managed this?
Cheers
Is it that the dash i have been given is too new? did Ford make a cable drive speedo for any Mark 5 type dash clocks?
Have found the thread by the chap who has done this but no mention is made of speedo drives.
Thanks Again
Northfalia
Re: Mk4 Dashboard swap
Postby Northfalia » Mon Nov 10, 2008 6:32 pm
Anyone?
Northfalia
Postby Luke » Mon Nov 10, 2008 6:39 pm
taken from another thread :D
Bryan wrote:It's not possible to change the heater box to a mk5 one when changing the dash you have to make do with the mk3/4 one already in the van because the bulkhead is shaped completly different. I thought about cutting out the bulkhead from the mk5 and welding it into the mk4 but that was too much work.
I just need to get some universal air ducting and direct the air vents to the heater box because the old venting won't work with the mk5 dash.
Looks like someone has spent a lot of time on your van as the dashboard swap isn't as easy as it seems!
Postby Northfalia » Mon Nov 10, 2008 6:44 pm
Nice one, thanks, Speedo?
Northfalia
Postby Luke » Mon Nov 10, 2008 6:46 pm
speedo i'd have just thought an early mk5 one would do as they were cable :D
Postby Northfalia » Mon Nov 10, 2008 6:47 pm
Thats great news, am past the point of no return!
Many Thanks
Northfalia
Postby Luke » Mon Nov 10, 2008 6:54 pm
Postby dark legend » Tue Nov 11, 2008 10:00 pm
Speedo drive is cable on my N-Reg Mk5 Donor..
dark legend
Postby Northfalia » Tue Nov 11, 2008 10:40 pm
thanks again folks for help and advice, Just hope its all worth it!
Northfalia
Postby sos recovery » Wed Dec 09, 2009 11:32 am
ifits any help ive just bunged a mk5 dash electrics and heater etc into a mk3 found these probs ....an inch gap at the windscreen [grafted onthe original bit from the mk3 sorted !,my dash is electric and i need a set of cable clocks ..folowed the therad on here about converting the dash to later instruments works atreat cept my speedo doesnt obviously work now but evryting else does [anyone got a set of clocks they dont want ..mail em to me plzzzzz no one on evilbay will send em out here]..apart form a few fitting issues it was a doddle [had to do a bit of cut and shut onthe bulkhead to accept the new heater but other than that no worries
Nemo Mi Impune Laccesit,or as they say in Glasgow Get tae F=== ya Bassa
sos recovery
Postby Anton2k3 » Wed Dec 09, 2009 4:39 pm
I also found fixings from mk3 to mk5 at the back of the dash were different. I squirted a big of expanding foam in the holes, worked very well. Also the A pillar trims didn't fit perfectly, so again, expanding foam and taped them in place, all nice and lined up now.
Heater matrix is not difficult, just use self tappers to re-fix it. I read in another post someone used the top mk3 holes to bolt it in, but later found it was too high, so just take your time getting it positioned. I took a pater template from the mk5.
Anton2k3
