My Mechanic had a quick look at it said the fault was in the switch, a replacement here in Australia is over AU$200.00, I don't know how they make them so cheap Falls of chair laughing).
All the fuses are fine, I pulled off the cover under the switch that covers the fan box and found a green relay, no sign of burn out when I lifted the cover off it.
I need to get to the back of the switch but how do I remove the middle dash that holds the clock radio and so on
PS If I select speed 3 and push the selector in the electric cooling fan on the condenser runs, and air flow, but nothing else gets me any air flow
1998 smiley, 2.5 turbo diesel.
