Sparky wrote:thanks fred i have just had alook around the engine there seams to be a little oil or diesl around one of the egr pipe that goes on the manifold oh bye the way fred how do i get a pic of my van on the site tar
bazw wrote:fred whats how to post a photo got to do with an asmatic transit?
daddy cool wrote:Your van wheezes, does it smoke?![]()
Sorry
pictishpunkgirl wrote:The wheezing could well be leaking EGR vacuum pipes - this causes a whistling or wheezing which is particularly evident when you take your foot off the accelerator. If you do seem to have a leak, try sealing it as best you can temporarily just to see if the noise goes by getting someone to hold the pipe on hard or block the leak by hand if you can. A tiny leak can cause a loud enough wheeze to be heard in the van while it's going.
Morag
joelataxi wrote:pictishpunkgirl wrote:The wheezing could well be leaking EGR vacuum pipes - this causes a whistling or wheezing which is particularly evident when you take your foot off the accelerator. If you do seem to have a leak, try sealing it as best you can temporarily just to see if the noise goes by getting someone to hold the pipe on hard or block the leak by hand if you can. A tiny leak can cause a loud enough wheeze to be heard in the van while it's going.
Morag
also check the brake vacuum pipes, same type of sound
