is it possable to convert to a up and over rear door
Postby cossy tranny » Thu Feb 09, 2006 11:34 pm
as above to a swb 98 smiley if so what do i need to do this . any help would be great even if anyone hass the stuff for sale thanks
cossy tranny
Postby Luke » Thu Feb 09, 2006 11:47 pm
not done it, but the top hinges have a raised part on the side panels - this would need cutting off to look right!! :D
Postby cossy tranny » Fri Feb 10, 2006 12:01 am
im a panel beater / spray painter so this should be ok
cossy tranny
Postby Luke » Fri Feb 10, 2006 12:06 am
i think this question has been asked before but ive done a search and i cant find it!!
Postby cossy tranny » Fri Feb 10, 2006 12:09 am
hopefuly somone wll know about it
cossy tranny
Postby DOL » Fri Feb 10, 2006 5:57 am
MY MATE FITTED ONE TO MY OLD F REG S.H.T AND IT WAS FINE,ALL I DID WAS FIND A BREAKERS WITH ONE IN AND TOOK THE DOOR,GAS RAMS AND FIXING BOLTS THE LOCK CATCH PLATE AND CUT THE ROOF WHERE THE HINGES ARE(THE WHOLE BIT FROM LEFT 2 RIGHT) AND HE WELDED IT IN AND PLATED AND FILLED ABOVE THE DOOR,I WOULDNT MIND FINDING ANOTHER ONE FOR MY PRESENT VAN AS THEY LOOK SO MUCH BETTER THAN TWIN DOORS
Image 1 by 1 the penguins keep stealing my sanity!!
DOL
Formerly known as Dafodol.
Postby FredTransit » Fri Feb 10, 2006 10:14 am
No too sure about the Mk3, but on the Mk2 there is a panel the door mechanism attaches to, and the spring for the door is braced with it. I have seen this conversion on the Mk2 done by taking a slice of roof from the donor, dunno about the Mk3 though.
FredTransit
Mk2 Trannyist
Postby madmark » Fri Feb 10, 2006 1:13 pm
no fred the mk3 is on strutts! :shock: with abit of messing its possible! but you need to get all the parts of a scrapper! :)
