Speedo cable
Speedo cable
Postby Daveathome » Sun Feb 12, 2006 10:01 am
Hi all I have a Mk5 Di and the speedo has stoped working ??
I looked behind the dash but there seems to be no cable only wires
Any ideas ? sorry not got a manual yet lol :D
Daveathome
Postby MrMPuk » Sun Feb 12, 2006 10:33 am
From memory yours is a 98 non-turbo Di which is the same as mine and from what I recall I have a cable, so haven't got a clue.
Postby Daveathome » Sun Feb 12, 2006 10:37 am
yes it is a 98 non-turbo Di i have checked again and there is only two sets of wires which plug into the back
Daveathome
Postby MrMPuk » Sun Feb 12, 2006 11:18 am
Have you checked the fuses?
Postby Daveathome » Sun Feb 12, 2006 11:26 am
Yes checked all fuses and all ok
Daveathome
Postby MrMPuk » Sun Feb 12, 2006 11:26 am
When you had the instrument pod out did you check to see if there were any burnt out tracks on the PCB?
Postby 100ps_drw_hicube » Sun Feb 12, 2006 12:14 pm
is this a later speedo with electric speedo drive????? as our 98 hicube has got the electric speedo drive it is a turbo but has the ordinary speedo no rev counter :(
100ps_drw_hicube
Transit Abuser!!
Postby Daveathome » Sun Feb 12, 2006 1:37 pm
I guess it is the new one as there is no cable, yes i looked at it and there seems to be no burnt bits anywhere, i was thinking of getting a new instrument pod but the mileage would be out and it may be gearbox end or wherever it reads the speed/mileage ?
Daveathome
Postby MrMPuk » Sun Feb 12, 2006 1:40 pm
Could be the speedo pick up on the gearbox, the only other thing to say is check your wires.
Postby Daveathome » Sun Feb 12, 2006 1:42 pm
do you know where the speedo pick up on the gearbox is i had a look but it has a cover around the gearbox and i didn't want to pull it off if i can get to the wires,??
Daveathome
Postby Luke » Sun Feb 12, 2006 1:53 pm
should be towards the back on the drivers side!! :D
Postby Daveathome » Sun Feb 12, 2006 2:38 pm
thanks when it stops rainning i will have a look :D
Daveathome
speedo cable
Postby sean » Sun Feb 12, 2006 4:29 pm
:D hello ther mate :) :? does your clock pod not have a recess in the back for a speedo :?: :? :)
sean
Postby Luke » Sun Feb 12, 2006 9:18 pm
Luke wrote:should be towards the back on the drivers side!! :D
looked at me mt75 electric speedo box today and it was on the other side!! so check both sides :? :lol:
Postby Nighthawk » Sun Feb 12, 2006 10:17 pm
The VSS is indeed on the passenger side of the transmission at the rear end of the box,
Are you sure you checked all the fuses on the bottom row of the fuse box?
from memory, some transits had incorrectly labeled fuse box lids and the speedo symbol on the lid was 1 fuse or so out of position.
The speedo head itself is a known failure point though.
Nighthawk
