cold start device playing up?/
Postby escort » Sat Jan 24, 2009 8:15 pm
hi all ive got 1995 2.5 deisel with turbo conversion and seperate cold start device bolted to pump
the van starts first time everytime evern on the coldest days but i think the cold start device is staying on too long ive checked for a voltage so i know the engine sensing switch is ok
if i start the van and leave it running on drive it can take as long as half an hour to opperate the device and drop the revs
will this do any damage to the engine ? as the device advances the pump as well as increasing the idle revs ?? thanks
george
escort
Re: cold start device playing up?/
Postby psv-hgv-flt » Sat Jan 24, 2009 8:31 pm
what duz the temp gauge read, is temp sensor wire off, or have you taken thormastat out. (CHECK THESE)
psv-hgv-flt
Postby escort » Sat Jan 24, 2009 8:51 pm
temp gauge is ok just out of the blue before the device lowers the revs im more concerned weather it could damage the engine because its staying on to long
george
escort
Postby psv-hgv-flt » Sun Jan 25, 2009 12:15 am
it be ok, just renew thormastat (with the highest 82 or 88c) :wink:
psv-hgv-flt
Postby Frag » Sun Jan 25, 2009 12:11 pm
Shouldn`t take half an hour,although left ticking over engine will take ages to get warm.
Think block temp switch should make circuit at 11 degrees + to knock coldstart off,this is well before temp guage even registers.
Frag
Ford Technician
Postby escort » Sun Jan 25, 2009 6:32 pm
ok thanks but will it damage the engine because of the fact that the pump timing is advaced until it kicks in?
george
escort
Postby psv-hgv-flt » Sun Jan 25, 2009 8:37 pm
no, but i would renew thormastat
psv-hgv-flt
Postby escort » Sun Jan 25, 2009 10:33 pm
hi dont think thermostat will make any differance as ive checked for a voltage at the cold start device and i get 12volts well before the device kicks in so im thinking the device itself is slow to respond
george
escort
Postby lewdale » Sun Jan 25, 2009 11:40 pm
if youre that bothered then why not put it on a switch on youre dash? then u can control it
lewdale
Postby AndyG » Sun Jan 25, 2009 11:54 pm
lewdale wrote:if youre that bothered then why not put it on a switch on youre dash? then u can control it
I love these simple ideas :!: :D
A choke overide switch 8) (should fit nicely in one of the many blanks)
Postby escort » Mon Jan 26, 2009 10:40 pm
thats an idea but i still need to know roughly how long the device should take so i know if its working correctly
george
escort
Postby Frag » Tue Jan 27, 2009 1:39 pm
If you need to know i`ll time mine from cold,see how long it takes from getting 12v to being fully off :)
Frag
Ford Technician
Postby escort » Tue Jan 27, 2009 8:53 pm
nice one frag
george
escort
Postby Frag » Fri Jan 30, 2009 5:07 pm
Right,fired van up from flat cold left it ticking over & timed it:
4 mins,switch makes circuit & coldstart solenoid gets batt voltage.
6 mins can hear engine revs starting to drop as coldstart is "pushed off"
8 mins coldstart is fully off.....
That was at todays outside temp,cooling system & stat on my van is spot on.
This should help you :D
p.s. even after this,temp guage hasn`t budged & that works fine too.
Frag
Ford Technician
Postby escort » Fri Jan 30, 2009 8:58 pm
thanks for your help frag ill time mine tomorow but im sure mine takes longer than that you have got the same bolted on cold start device ?
if mines slow [knackerd] how much would a new one be any ideas? thanks again mate
george
escort
