Eberspacher Ticking
Eberspacher Ticking
Postby yrocker » Fri May 01, 2009 1:08 pm
Hi
Can anyone tell why I hear a ticking noise when the heater is running?
Also if you can, where is the sound coming from?
I cannot for the life of me locate the source of the sound.
Mk5 LWB Hitop ex-BT 2.5D now converted to turbo intercooler.
Interior now 2 berth camper with fridge, toilet and warm air heating.
Usually to be seen towing my 1963 Anglia on a trailer.
Len
yrocker
Re: Eberspacher Ticking
Postby riche100 » Fri May 01, 2009 1:18 pm
look underneath deep tray ontop of dash .
i collect old fruit machines , if anyone has any or knows of any from the early 80s to 90s please :)
riche100
Postby madmark » Fri May 01, 2009 1:25 pm
the ticking will be the fuel supply feeding the heater! :wink:
Postby psv-hgv-flt » Fri May 01, 2009 4:08 pm
madmark wrote:the ticking will be the fuel supply feeding the heater! :wink:
as said, but more noise if air in lines.and a bitch too get out.?? :wink:
psv-hgv-flt
Postby yrocker » Fri May 01, 2009 7:52 pm
Thanks for the info.
I won't worry any more. :lol:
Len
yrocker
Postby bwebb84 » Thu May 14, 2009 11:05 am
Hi,
I've just got an Ex-BT van complete with the Eberspacher D2. I can get air to blow out but not heated, and it makes a ticking noise. Guessing it's a fuel pump of some kind as mentioned above, If so is this ticking normal?
Does it run off the main diesel tank?
bwebb84
Postby psv-hgv-flt » Thu May 14, 2009 1:31 pm
bwebb84 wrote:Hi,
yes, from tank, but should get hot tho after 2min.??
psv-hgv-flt
Postby redbox4wheels » Sun Feb 28, 2010 8:53 pm
Anyone know how do you get the air out of the system, it doesnt seem to be stopping it working, but the ticking is just too loud, its like chinese torture.... none of the clips etc is touching any metal etc. Also anyone know if going in through the 'sender' with the 'drinking tube' the bung on the top of the drinking tube should be push right down the sneder tube or just sit on the top.? THANKS
redbox4wheels
Postby psv-hgv-flt » Sun Feb 28, 2010 10:41 pm
redbox4wheels wrote:Anyone know how do you get the air out of the system, it doesnt seem to be stopping it working, but the ticking is just too loud, its like chinese torture.... none of the clips etc is touching any metal etc. Also anyone know if going in through the 'sender' with the 'drinking tube' the bung on the top of the drinking tube should be push right down the sneder tube or just sit on the top.? THANKS
rap it with thick padding and check the rubber mount. this link might help.
http://eberspacher.com/downloads/techni ... hnical.pdf
http://eberspacher.com/support-and-down ... ments.html
:wink:
psv-hgv-flt
