stuck in reverse
stuck in reverse
Postby rossi » Sun Jun 21, 2009 11:03 am
i think i posted wrongly in connect section
so il try again
i have a 99 transit 100
i removed gearbox to repair snapped clutch release lever
on refitting when in neutral box is in reverse and gears are very stiff and i cant get 1-3-4 or 5
can anyone help
rossi
rossi
Re: stuck in reverse
Postby zephyr » Sun Jun 21, 2009 11:33 am
I had something similar with one of mine a while ago. It go stuck in first though. It turned out that the selector at the base of the gear stick had jumped out.
To fix mine, I lifted out the gear stick by undoing the three(?) torqs bolts at the base, lined up all the sliders underneath where the stick was bolted in so that the box is in neutral and then droppped the stick back in. It doesn't look possible but trust me, the selector can slip out. May not be what has happened to yours but its a fairly easy thing to try.....
If its not that then it may be something more serious such as mechanical failure of the selector forks inside the box. :?
Fingers crossed for you.
Transit...... The first and best MPV
zephyr
Postby rossi » Sun Jun 21, 2009 11:53 am
thanks for reply zephyr
it sounds like it could be this as i havent touched box other than taking it out
il give it a shot and report back
rossi
Postby rossi » Sun Jun 21, 2009 12:05 pm
sorted
your a star mate
lined em up put lever on and bingo
thank god for internet i could have been at it for days
rossi
Postby zephyr » Sun Jun 21, 2009 12:18 pm
Glad I could help and happy you got it sorted. Well done! :D
zephyr
