Hi Guys, just noticed this thread,
Had a few e-mails about this so here's some info about what i did to get it to fit.
The spare wheel cover i made from a Vauxhall frontera wheel cover,but i had to cut about three to four inches off the end of the band as it was too long.
you will also have to make new slots in it so the locking mechanism works and cut the centre (blue bit on my van) down by the right size too.
The bracket for holding the wheel to the door is from a Suzuki vitara (1988/1996) model.
I used two inch square steel plate about 3mm thick as washers to spread the load inside the door,after three years there is still no sigh of any
cracks so all seems to be fine.
The bracket will need the vitars bolts cut off and new bolts welded on to the transit stud pattering.
The ladder is home made out of 19mm round bar and a b&q pipe bender.
Hope this all helps
Willie
