SPARE WHEEL REMOVAL ON 95 LWB/HTOP PROBLEM.
Postby axzed » Wed Apr 12, 2006 10:35 pm
Hi all. I know u featured this previously but I am still stymied. I can't get a close up of the winder socket. My Ford jack handle has a pyramid profile 'bell' end covering an hexagon socket. It can't couple with the winder mechanism & I concluded that I need a male hexagonal extension, but then again, there's nowhere for a springloaded ball 'catch' to
locate. HELP - Gotta use it on Sat.
ANYONE GOT A REAR DOOR HANDLE ASSEMBLY? I only require the casting that actuates the locking rods/bolts.
cheers
axzed
Postby 100ps_drw_hicube » Thu Apr 13, 2006 10:26 am
i have the handle bit you need pm me for more info :D
100ps_drw_hicube
Transit Abuser!!
Postby oldsaltoz » Fri Apr 14, 2006 3:51 am
Try locating the handle then give it a hard push or even a tap with a hammer, worked for me, but I now store the spare in the back of the van.
1998 Mk 5 Smiley, 2.5 diesel turbo, LWB Mid roof. Mobile tool box and storage.
oldsaltoz
