I have just got an R reg 2.5 D and when i go to start it the red light in the headlining flashs really fast and the brake warning light comes on when you try and start it,
Please help as i need to get to work asap
Cheers Colinlgv
How did you manage to take delivery of the van, in that case? Is that the only key you have?colinlgv wrote:it had a 2nd hand barrell and key fitted and the chip swapped because the barrel collapsed and since then it has not started
MrMPuk wrote:Red keys were only on the early Mk5's, after that you needed 2 original keys to program new keys.
madmark_50484 wrote:MrMPuk wrote:Red keys were only on the early Mk5's, after that you needed 2 original keys to program new keys.
every smiley Ive driven (up to V reg) has had a red key so you must have the red master key to program it up.
You can only use 2 keys to program if you have a blue chip in your key
Users browsing this forum: Peterr
