This is from my donor van (A mk5 W reg):
And I'd like to know if the injectors would go into this (A mk5 P reg):
The injectors are shot in the P reg and I'd like to replace with the ones from the W reg if possible. They look the same engine appart from the air filter housing and the W reg has had the EGR mod done to it. The W reg also has a Lucas injection pump, the P reg has a Bosch - shouldn't make a difference should it?
Thanks in advance.
