petrol to diesel
petrol to diesel
Postby little nat » Fri Apr 28, 2006 12:51 pm
Hi, im a new user of the forum, i hope you can help.
My dad is putting his 2.5d engine into my 2.0 petrol. Both are LWB 1991 vans and at the moment things seem to match up ok.
Can anyone tell me if the wire from the loom which goes onto the carb will go onto the diesel pump solonoid?
We are novices at engine swapping but my little horse box needed some more torque!
little nat
Postby Gunslinger » Fri Apr 28, 2006 1:35 pm
i "think" thats the case .... but you'll need someone else to confirm it .... i swapped 2,4 diesel for 2.5di, so i didnt have that particular question/problem
Gunslinger
Postby motorwise » Fri Apr 28, 2006 6:07 pm
you just need an ignition controlled live so that wire will be fine for the job
good luck
http://www.motorwise.net
motorwise
Postby crazyscoot » Fri Apr 28, 2006 7:36 pm
check you have live supply when the ignition is on and dead when ignition off. as motorwise said above :D
Negative reality inversion
crazyscoot
Postby little nat » Fri Apr 28, 2006 9:40 pm
Many thanks , we will give it a whirl.
Im sure i will have some more questions soon.
little nat
