Hello Collective Transit wisdom:
The condensed version of my query:
1999 2.5 Turbo diesel not starting, get blow back diesel mist via the air inlet.
Could the partially torn timing belt (image link below) have "ridden over" the injection pump pulley and thrown the timing out?
The long version of my query:
The Transit is a 1999 2.5 TD (Blue dot on injector pump) 180.000 Kms, LWB, mid roofline,
has ben 1st key-turn starter for ever.
Then suddenly...... one afternoon the guy driving it reported that it kept stalling at idle, and he promptly ran (low speed tap lucky!) in the towbar of the car in front.
No major damage, but no way of starting it since! After towing it home we discovered that one or both of the alternator & Pwr Steer belts had come off and wound themselves very, very, very tightly around the crankshaft pulley (possibly the cause for the stalling at idle)
I replaced both belts, but no start,so then I tested:
Fuel in tank = OK 60% full
Uplift pump = OK strong & fast flow from the filter
Diesel Filter = I replaced it in case it was clogged (no change)
Cracked the injectors = nice & strong squirts of fuel
Purged the lot, then tested return fuel line from injection pump = No air bubbles, but a strong flow of diesel.
A (poor quality) AVI movie of the non starting can be seen at:
http://www.zippyvideos.com/7880610145002426/nostart/
If you see the video above you will notice fumes/smoke wafting past the lens, and its coming from the air inlet ! Yes from the head, back to the manifold and past the airfilter and up to the inlet !!
The fumes (I'm pretty certain) are non-combusted diesel/air mix,
Now methinks that the timing belt is the likely candidate, as we discovered that this belt is split (likely caused when the other belts wound around the crankshaft)
The split in the timing belt can be seen in the image below
http://www.imagehosting.us/index.php?ac ... nt=1334711
Thanks for your help
Stefano
(This is a long post, I realize, if inapproprate, please advise me and excuse my shortcomings in forum etiquette !)
