Transit diff change
Transit diff change
Postby transit nut » Thu Nov 19, 2009 6:56 pm
Hi,
i havent been on here for a long time SORRY !
My 2000 LWB 2.5Di is very slow and id like to change the diff on the back axel so it would go faster n use less fuel, is it easy to do and how difficult is it to find one?
Thanx Mark
transit nut
Re: Transit diff change
Postby MinorMatt » Fri Nov 20, 2009 12:03 pm
well it depends what axle and what diff ratio you already have
Postby Highlander250469 » Fri Nov 20, 2009 4:31 pm
transit nut wrote:id like to change the diff on the back axel so it would go faster n use less fuel
When you say yours is slow do you mean accelerating or top end speed?
If you're changing the diff for higher top speed/lower revs/better mpg you're going to lose acceleration
If you're changing it to make it accelerate quicker you're going to lose MPG and top end speed
My 94 2.5D did about 85 flat out and took a week to get there :)
Highlander250469
Postby transit nut » Mon Nov 23, 2009 9:08 am
Thanx guys.
its a 2000 W reg LWB Model 100. Im lucky to get 75mph out of her (thats on a Road Angel not the speedo ) id like a bit more top end. Dont know what diffs on her. Years ago i had a twin wheel Mk2 face lift Di with an overdrive G/Box that did 90 on the clocks. Would love this van to be closer to 90mph than 80
Thanx everyone Mark
transit nut
Postby streetmech » Mon Nov 23, 2009 9:33 am
transit nut wrote:Hi,
Thanx Mark
It's not possible to go faster and get better mpg.
changing gear ratios doesn't remove wind resistance.
If you want better mpg you have to go slower.
Pete.
streetmech
Postby AlanN » Mon Nov 23, 2009 11:08 am
This thread will help identify what you should already have... is it 5 stud :D or 6 stud :(
Although mine is a MK3, I changed from the worst axle I could have for a pleasure van (5.14) to a 3.9. Its without a doubt, the best thing Ive ever done on the van. Until I fit my V6 that is... :lol:
Postby MrMPuk » Mon Nov 23, 2009 11:50 am
If you're getting 75 then I doubt you will get a better diff, if you were to fit a better diff you would find that the van would be dying on hills.
Postby Highlander250469 » Mon Nov 23, 2009 9:51 pm
streetmech wrote:It's not possible to go faster and get better mpg.
Pete.
I think what he actually means by faster is a higher top speed.
And a better mpg for the same speed, not the faster speed
cruising at 70 mph with a 3.9 diff will return a lot better mpg than cruising at 70 mph with a 5.14 diff (assuming the power is available to do it)
I changed the diff on a car from 3.91 to 3.36 as I do a LOT of motorway stuff, its a bit slow taking off but not too noticeable, however on the motorway it cruises about 700rpm lower than before and returns around 8 mpg more
Highlander250469
Postby Wambo » Sun Dec 06, 2009 4:33 am
AlanN wrote:...I changed from the worst axle I could have for a pleasure van (5.14) to a 3.9. Its without a doubt, the best thing Ive ever done on the van. Until I fit my V6 that is... :lol:
Hi Allan, I too have a 5.14 and wish to change to a taller diff for better MPG. Mine is a 6 stud and the best options are in the 5 stud axles. Was your 5.14 a 6 stud? Did you put a 5 stud axle in?
Build Date: 31.08.1999
Vehicle Line: Transit 95
Cab Style: Regular Cargo Van
Series: 190L
Engine: Diesel 2.5T (100PS)
Transmission: 5-Speed Manual - MT75
Axle Ratio: 5.14
Territory: (+)"AUS"
Wambo
Postby MinorMatt » Sun Dec 06, 2009 11:50 am
AlanN's Van was a 5 stud axle.
The best ratio avaliable for the 6 stud is 4.63
Postby AlanN » Sun Dec 06, 2009 5:50 pm
As Matt says... but still look for a 4.63, remember to get the speedo pinion to go with it, out of the gearbox
Postby madbri » Sun Jan 24, 2010 10:31 am
ive got a six stud high cub with a 5:14 diff. if i fitted a 4.63 diff dose this make the top end speed more? and also if i were 2 keep it at 60mph as the old diff dose will it improve me mpg? or am i better giong the whole hog and changing the axle for a 5 stud 4.11 any issuse between 5 stud 6 stud ie law/fitting the same under van ect THANKS :wink:
madbri
Postby MinorMatt » Sun Jan 24, 2010 12:29 pm
If you fit a 4.63 you will be doing less revs for a given speed - so in theory the top end should increase. If you are driving at 60 with a 4.63 it will be doing less revs than a 5.14 so I guess the economy should improve! a 4.63 will have less pulling power though, so if you are always running heavy your MPG may decrease.
With regards to fitting a 5 stud axle (I havent looked in to the legalities of it yet - but its what I am planning to do) I would imaging you would need to downplate the van as the 5 stud rear axle isn't rated as highly as the 6 stud in terms of load capacity (you will also need to tell your insurance company)
Postby madbri » Sun Jan 24, 2010 4:46 pm
thanks matt if i did change the axle id pretend i didnt as the insurance would want to no the ins and outs of a dogs arse. its a camper so id just play syupid and say the last owner must av changed it ! there must b loads of wrong bits on transits that honest people dont no! but let us no bout the change over :wink:
madbri
Postby MinorMatt » Sun Jan 24, 2010 5:05 pm
it will be a while yet! Im going to redrill the axle and I havent got all the kit yet!
Matt
