the thing was though, i fitted the condenser and evaporator and pump and electrics but had to get a fridgeman to gas it up there was a slight leak from a reversing valve that i had fitted he didnt like the pipes i had extended (it was a freezer from a ldv cub and i put it on a mk5 chassis cab with a big stainless box ) didnt like my pump bracket but had a secondhand one he put new aircon pipes on took of my 60 quids worth of new reversing valve as it wasnt going to be used as a freezer didnt need it apparently. dried it out gassed it up 600 quid later it was a good un
i think the refrigerant was about £150 of that and when i took it off the ldv i just took a pipe off and let it go. i found it very difficult to find any how to information but you never know till you have a go. if you do find a scrappy one its something to bear in mind and get one with a standby
