Mk3 to smiley
Mk3 to smiley
Postby Andrew E » Tue May 02, 2006 12:27 pm
I did a search honest.... doing a smiley conversion on a mk3 - apart from lights an a bonnet - what else ? do you need the front panel ?
Cheers Andrew
Andrew E
Postby rover » Tue May 02, 2006 1:16 pm
As far as I know the 'Slam panel' is the same, but I think the front wings are slightly different.
You will need the front bumper too.
Rover.
rover
Postby Transitwalla » Tue May 02, 2006 1:21 pm
Wings for definate are different . . just in front of the indicator repeater. In the MK3 the bodyline continues to the front of the wing...in the MK5 it doesn't . . it stop just behing the indicator repeater. This I know as I sized up a MK3 wing to the front of my MK5 . . come to think of it aren't the repeater lights a different shape :?:
Imagination....our only limit....
there's no such thing as a daft question.
Jim.
Transitwalla
Postby Andrew E » Tue May 02, 2006 2:41 pm
Oh well stays as it is then :cry:
Cheers for the replys guys :)
Andrew E
Postby crazyscoot » Tue May 02, 2006 6:28 pm
side repeaters, headlamps, bonnet, wings, bumper, slam panel (not sure)
Negative reality inversion
crazyscoot
Postby 100ps_drw_hicube » Tue May 02, 2006 6:50 pm
slam panel is definately different :D
100ps_drw_hicube
Transit Abuser!!
Postby Luke » Tue May 02, 2006 7:08 pm
crazyscoot wrote:side repeaters, headlamps, bonnet, wings, bumper, slam panel (not sure)
also indicators, scuttle panel :D
100ps_drw_hicube wrote:slam panel is definately different :D
is it different mk4 to mk5 :?: how :?: cos my mk4 has the mk3 one on :?
im suprised no-ones mentioned this one!!!
http://www.fordtransit.org/forum/viewtopic.php?t=1753
Postby 100ps_drw_hicube » Tue May 02, 2006 7:20 pm
mate mk4 is defo different to mk5 and i always thought that mk3 was different to mk4 :? maybe not :? (i tried fitting mk4 bonnet to mk5 latch is 6 inches towards the middle on the mk4 :roll:
100ps_drw_hicube
Transit Abuser!!
Postby Luke » Tue May 02, 2006 7:30 pm
100ps_drw_hicube wrote:mate mk4 is defo different to mk5 and i always thought that mk3 was different to mk4 :? maybe not :? (i tried fitting mk4 bonnet to mk5 latch is 6 inches towards the middle on the mk4 :roll:
ah right :!: im 95% sure i fitted the mk3 slam - i can check i still have the mk4 one - they may have got mixed when they were on the floor!!
so a mk5 bonnet wont fit on my mk4 :?: without fitting a mk5 slam :shock: i didnt realsie that :!: - its amazing how many little changes there are between each mk i didnt realise mk3s were so different to mk4s untill i just broke these 2 together :!:
Postby 100ps_drw_hicube » Tue May 02, 2006 7:33 pm
ye mate you need the matching slam panel as ifound out ended up redrilling the bonnet and using riv nuts to relocate the striker :evil: :evil:
100ps_drw_hicube
Transit Abuser!!
Postby Gunslinger » Tue May 02, 2006 7:47 pm
Gunslinger
