Weird noise with engine not running!!
Postby spondootre » Wed May 03, 2006 8:32 am
OK for a while now I intermitantly hear a weird noise from under the van with the engine off, it may happen when it'sd running but I don't hear it. It sounds like a pump or something and last for about 10 secs at a time. If it happens while i'm around the van I dive under it to see if I can find the source of the noise but i'm stumped!! It comes from somewhere near the petrol tank which made me think of some kind of pump, but why would it be pumping when the engines off?
It's a 1992 K reg SWB 120 Petrol
Cheers
Malc
spondootre
Postby spondootre » Wed May 03, 2006 10:55 am
OK, so I was working on the interior today, heard the noise and dove under the van and it wasd this that was vibrating away!!, what is it and why is it doing anything with the ignition off?!
spondootre
Postby spondootre » Wed May 03, 2006 4:37 pm
Is it a pump? Is it supposed to have something else connected to it? It only appears to have one pipe connected to it si it doesn't make sense to me what it does!!
Help!!
spondootre
Postby rover » Wed May 03, 2006 5:00 pm
I get the feeling no-one knows, I have never been near the tank on a DOHC engine but I would imagine that if it has no wires going to it then its a pressure maintainance valve of some description, similar to the ones Vauxhall Calibras/Vectras have, to keep the pressure at a certain level so the injectors will open on cranking..
Could be completely off target of course :?
Rover.
rover
Postby spondootre » Wed May 03, 2006 6:11 pm
If it is that then would the vibrating noise just be it releasing air? I've had another look and there definitely isn't any wiring connected to it just the one pipe.
spondootre
Postby rover » Wed May 03, 2006 6:26 pm
IF it is that then yes.
Does the van start straight away without having to turn over much?
Rover.
rover
Postby MrMPuk » Wed May 03, 2006 6:31 pm
It looks as if something should be attached on the bit on the right though. I'll have a look and see if the Cossie has got one as that has a tank from a DOHC van.
Postby spondootre » Wed May 03, 2006 6:54 pm
Yep it usually fires up straight away, every now and again it'll turn over for ages but usually it's OK.
I thought that perhaps the bit on the right looked like it was supposed to have something connected to it but i've been out again and had a look up it and there doesn't appear to be any type of connection receptor or owt, perhaps it's just the outlet for air then.
spondootre
Postby motorwise » Wed May 03, 2006 6:56 pm
looks like the tank vent - they do make strange noises from time to time as they expell air (specially in hot weather)
http://www.motorwise.net
motorwise
Postby spondootre » Wed May 03, 2006 7:01 pm
That makes sense too, as i've noticed it more since the weathers been a bit hotter. I think I might attach a whistle to it for a laugh!!
spondootre
Postby motorwise » Wed May 03, 2006 7:05 pm
spondootre wrote:That makes sense too, as i've noticed it more since the weathers been a bit hotter. I think I might attach a whistle to it for a laugh!!
take the one off your kettle :wink:
motorwise
Postby Luke » Wed May 03, 2006 8:19 pm
thats the tank vent innit??? mine has one!!! :D
and who says its a dohc - pinto innit??? :lol:
Postby spondootre » Wed May 03, 2006 8:44 pm
Yep it's a pinto.....I think!! lol, is it missing a bit off it? or is that what it's supposed to look like?
spondootre
Postby Luke » Wed May 03, 2006 9:36 pm
spondootre wrote:is it missing a bit off it? or is that what it's supposed to look like?
cant remember does look like a bits missing and ive just binned my petrols tank - litereally 2 days ago :x but i thought the diesel tank had one too - i'll have a look see :D
Postby rover » Thu May 04, 2006 8:56 am
Well if its a vent then thats really not fair....Mine hasnt got one! The first thing I did was go out and have a look.... I want one! You lot get all the best toys :cry: :cry:
Rover.
rover
