my pick up or chassis cab, whatever the correct term is? failed its mot on the rear light panel being rusty..the back side behind the wheels was pretty rotten!
ive taken the whole panel away now, it was just welded onto the end of the chassis rails with a couple of bolts holding the top in place.
i'm just wondering, does the replacement panel need to be fitted in the same way? ie, welded into place?
i'm thinking of using some ally panels, similar to the ones that drop down on the side of the pick up, cut this to shape and by using angled brackets bolt it to the end of the chassis rails.
surely all its there for is to hold the number plate and rear lights in place.
please give me your thoughts, whether i can do this or not?
thanks in advance.
