Diesel MT75 to pinto?
Postby Ken Edmonds » Wed May 03, 2006 3:31 pm
Hi.
A mate has just totally trashed the 'box in his pinto F reg Mk3. It's not the original engine and box so I don't actually know what year it really is.
The local scrapyard has a few Mk3s but they're all diesel with MT75 boxes.
Unlike cars there's obviously enough room but do they fit the engine?
Ken Edmonds
Postby rover » Wed May 03, 2006 3:47 pm
If you are saying that the van is a petrol without an MT75 but you can only find MT75 boxes then YES it will fit, but you need an adapter plate for the pinto engine to MT75 box, you may also need the propshaft but i cant swear to that one.
Rover.
rover
Postby Ken Edmonds » Wed May 03, 2006 4:40 pm
Thanks for your help. Looks like it might be as difficult to get an adapter as a non-MT75 box.
Ken Edmonds
Postby rover » Wed May 03, 2006 4:54 pm
What box has it got in now?
If its a type nine then one from a sierra would fit without too much hassle.
Rover.
rover
Postby MrMPuk » Wed May 03, 2006 5:21 pm
If you use a type 9 box from a sierra then the gearstick will be in the wrong place.
Postby Ken Edmonds » Wed May 03, 2006 5:27 pm
I worked that out, about an hour after deciding that the P100 box they had had got near enough ratios to be OK. :(
Ken Edmonds
Postby MrMPuk » Wed May 03, 2006 5:33 pm
It'll work if you don't mind having your gearstick here!
Postby rover » Wed May 03, 2006 5:46 pm
Why not just put an ad in the 'Wanted' section for either a box similar to the original or an adapter plate for a pinto to MT75 ??
Rover.
rover
Postby tractive-effort » Wed May 03, 2006 9:29 pm
tractive-effort
Postby Ken Edmonds » Thu May 04, 2006 5:32 am
Thanks for the link. I had already seen it. It's a ***** long way from Derbyshire to Essex!
My mate had tried a car gearbox on a previous tipper. It, like this one, had 3 seats and apparently it was fine as long as he didn't want to use 2nd or 4th. :)
Ken Edmonds
Postby Andy » Thu May 04, 2006 9:15 pm
There is of course the sierra MT75 box - as fitted to the granada and sierra 2.0 dohc engines.
It fits straight onto the pinto with no adapter plate required although you will have to change the pressure bearing to a longer one. It has an adaption for cars bringing the gear change further back - but this can be done away with leaving it roughly in the correct place for a transit.
Andy
Postby Luke » Thu May 04, 2006 9:20 pm
Andy wrote: It has an adaption for cars bringing the gear change further back - but this can be done away with leaving it roughly in the correct place for a transit.
still about 6" too far back tho :!: - i once wondered about this :idea: if you could change the linkage round so it pointed forward instead of back it would be about right :D but ofcourse that wouldnt be a simple thing to do :lol:
Postby Andy » Thu May 04, 2006 9:48 pm
I fitted one to a pinto in a kit car and had to extend the "extension" by about a further 3". I was simple enough to do - but if extending forward it would be harder to mount the extension to the bellhousing.
Thanks for the info
Andy
Postby Luke » Thu May 04, 2006 9:55 pm
the dohc transits use the mt75 with a dohc/pinto stud bellhousing :!: no adapterplate :!: and ofcourse the stickis in the right place too :lol:
Postby Ken Edmonds » Sat May 06, 2006 5:38 am
I've got a pinto-fit MT75 in my garage (bought for my kit car) but apart from the gear lever, the ratios are wrong for a Transit. Well, it's supposed to fit a pinto, I'd better check sometime...
As the tipper in question regularly carries a full 1.1/2 tonnes of tarmac, and Derbyshire is VERY hilly, low first, second and third are pretty important. :)
Ken Edmonds
