hi i have 1997 banna engine and had to chance the bleed off hoses twice this year is there silicone hoses i can use instead or something else i could do
oh not good is it,id try some good quality leak off hose...mine is 12 yrs old and no cracking visible or leaks.dont normally need to upgrade????has it had something other than normal diesel through at some point?
depends how old the stock is i had some a couple of years ago that was perished but at first site appeared ok new pipe as i thought but when fitted leaked badly .Get it from somwhere with a high turnover of pipe a diesel specialist for instance to be better able to get recently manufactured pipe.
try united diesels there prices are good delivery is quick and the pipe is good quality and you can order whatever length you want thay have a good website
is that dirt on my van ? no its ok just another bit of rust
