VIN code help needed
Postby TimothyUA » Sun Dec 06, 2009 4:43 pm
Hello everyone!
I own Ford Tranzit 1994, Decmeber. can someone help me check my VIN code for all info possible, particular rear axle gear?
Thanks a lot!
Here is the VIN:
WFOHXXGBVHRG04287
TimothyUA
Re: VIN code help needed
Postby AndyG » Sun Dec 06, 2009 5:46 pm
Transit 95, Diesel 2.5T (85PS), Diamond White 73
VIN Number: WF0HXXGBVHRG04287
Primary Features
Build Date: 01.12.1994
Vehicle Line: Transit 95
Cab Style: Kombi (M1)
Series: 100S
Engine: Diesel 2.5T (85PS)
Transmission: 5-Speed Manual - MT75
Drive: LHD RWD
Axle Ratio: 4.56
Emission: 93 EEC Emission Requirements
Air Conditioning: Less Air Conditioning
Territory: (+)"A"
Paint: Diamond White 73
Interior Fabric: Windrush G-C
Postby TimothyUA » Sun Dec 06, 2009 10:56 pm
wow, thanks!
Does that mean that I have a slow type of axle gear??? It lifts 1,5 ton, does not go over 115 km per hour, well, it hoes pump changed to Bosh mechanical, maybe that is one of the reasons?
Ha, presently the color is black, diamond white, what is it????
TimothyUA
Postby AndyG » Sun Dec 06, 2009 11:08 pm
It means, it can carry around a tonne and has the middle ratio axle out of the three available (quite common)
Your top speed tells me there's something wrong with your pump or it's settings :|
Postby TimothyUA » Mon Dec 07, 2009 3:26 am
Form what I gather, change from Lukas Epica to mechanical Bosh is always a reason for a slower speed.The way it is with me, the turbine is there, but hardly makes any difference, so I intend to install the car's original pump back.
TimothyUA
Postby madmark_50484 » Mon Dec 07, 2009 5:31 pm
The VIN code WFOHXXGBVHRG04287 breaks down as
Manufacturer Identifier: Ford Werke A.G. (Germany)
Body type: H
Line: Ford Germany (Own Assembly)
Assembly Plant: Genk (Belgium)
Model: V
Year: 1994 (some codes are used for more than one year)
Month: December
Production Sequence: -5713
Past
MK5 98 R reg Transit 190 LWB Semi hi Top
Mk5 98 S reg Transit 190 LWB High Cube
Present
Mk5 96 N Reg Transit Luton
Forum for bus enthusiasts and preservationists
www.busesuk.co.uk
madmark_50484
Postby TimothyUA » Tue Dec 08, 2009 8:22 pm
madmark, does it mean there were some chanages made? definetely, it is no white, tis' black))0
TimothyUA
Postby madmark_50484 » Wed Dec 09, 2009 10:05 am
If I am honest I don't know I had just come across this vin checker so was checking it out with your number although I would not be able to see anything had changed from what you have said.
Past
Present
www.busesuk.co.uk
madmark_50484
