Changing brake disc
Changing brake disc
Postby msjandu » Mon Dec 07, 2009 10:28 am
Hi, can anyone out there help. I've got a 1996 smiley face Transit 100 2.5 non turbo SWB. The front discs are worn. However, when I came to change them, I couldn't separate the disc from the Hub. The five nuts that hold the disc onto the hub were undone. Does the hub have to be drifted away from the disc? Any help or how to instructions would be very much appreciated.
msjandu
Re: Changing brake disc
Postby WINDSCREENGUY » Mon Dec 07, 2009 10:35 am
big hammer
formally grey van man.
2010 115 semi high mwb . Fully loaded.
WINDSCREENGUY
previously grey van man
Postby msjandu » Mon Dec 07, 2009 10:39 am
Hi Mate, do you think its just rusted together then. Ive tried hammering it but it doesn't seem to budge?
msjandu
Postby chris_gilly » Mon Dec 07, 2009 12:32 pm
i had the same problem i actually smashed the discs trying to get them off!
just used lots of brute force, leverage and wd40!
chris_gilly
Postby MIXA » Mon Dec 07, 2009 5:14 pm
Hi there i had torun a grinder across the face on mine it easy as you go thoughso as not to cut the hub face
MIXA
Postby valeterjack » Mon Dec 07, 2009 7:52 pm
I GOT THE GARAGE TO DO MINE knew they were a bugger to do :wink: :wink:
Imagemk5 nothing even comes close
www.scottish-vanners.co.uk
valeterjack
Postby msjandu » Mon Dec 07, 2009 9:09 pm
- sorted it. Did need reasonable force in the end, but it did come free. Thanks to each!
msjandu
Postby jimmymacvitty » Mon Dec 28, 2009 6:21 pm
Take out 3 of the wheelnut studs,using a soft face mallet.Find a long nut and bolt with thread all the way up.
Put the bolt through the stud hole,place the nut on the end so that you have got the bolt head on the stud side of the hub
and the nut on the disc side.
With the end of the bolt against the disc take the nut up the bolt until it is against the hub ,hold it with a spanner and then turn the bolt head with another spanner.The bolt will push against the disc freeing it from the hub.Once the disc starts to go move on to the next hole and then the last one.
jimmymacvitty
