Bosch fuel line connectors
Postby Jim Archer » Sat Dec 12, 2009 12:58 pm
Anyone know if you can change the seals in the Bosch push fit fuel line connectors?
I've got one that is leaking (lift pump) when it gets cold and letting air in - not what you want of a cold morning.
This must be a fairly common issue.
Failing that, will the earlier Lucas compression fittings match the Bosch pump threads?
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Re: Bosch fuel line connectors
Postby trannytek » Tue Dec 15, 2009 12:12 am
what van is it for ????
trannytek
Postby Jim Archer » Tue Dec 15, 2009 7:49 pm
Ah yes, might help. '97 2.5 DI non turbo, with Bosch pump.
One of the fittings leaks air as it'll start fine but misfire on 1 cylinder after approx 1mile, and is worse if you have to rev it a bit. Once over that bit it's fine.
I've got a Lucas pump with all it's feed pipes and fittings on another motor, and I solved the same problem by nipping the pipe fittings a wee bit.
Jim
Jim Archer
Postby trannytek » Fri Dec 18, 2009 4:40 pm
try some ptfe first just wrap it around the threads being carefull not to let any bits go down the pipe!! if not i have some brand new pipes on the cheap :) tenner a peice :D
trannytek
Postby Jim Archer » Fri Dec 18, 2009 7:45 pm
I'm guessing it's the seal(s) in the push fit connector that's leaking when cold - guess the O-ring(?) has gone hard.
Checked the pipe ends and don't think they are the problem as they're clean and unmarked.
Jim
Jim Archer
Postby trannytek » Mon Dec 21, 2009 5:49 pm
i dont quite get this, so its the pipe coming from the pump to the rail??? has a threaded union on one end and a push fit flare on the other??
trannytek
Postby Jim Archer » Mon Dec 21, 2009 8:01 pm
Nope, plastic fuel lines from tank, via lift pump and fuel filter housing.
One of the buggers leaks back overnight when cold, and I'm loath to put sealer on them in case I need to disconnect at any time.
Jim
Jim Archer
Postby trannytek » Mon Dec 21, 2009 8:42 pm
AHHH I C you might have to go to the stealers to get some new ones buddy :roll:
trannytek
Postby psv-hgv-flt » Mon Dec 21, 2009 8:52 pm
re pipe with jubile clips. (cut old ends off)
psv-hgv-flt
Postby hifly » Wed Dec 23, 2009 5:51 pm
psv-hgv-flt wrote:re pipe with jubile clips. (cut old ends off)
this is what i had to do, been fine since
hifly
Postby NoOrDiNaRy » Wed Dec 23, 2009 6:47 pm
I did too, dont use cheap rubber hose to join tho as i found that eventually the diesel attacked the rubber, made it swell and eventually rot away! This meant that i came out one day and started van and covered drive in diesel :roll:
NoOrDiNaRy
