Rear Door Weight
Rear Door Weight
Postby d4funky1 » Mon May 08, 2006 3:43 pm
Hi,
Does anyone know the weight of the rear doors on a transit (low roof)?
I've seen a couple for sale but there 200 miles away!!!
Trying to work out a courier charge.
Many Thanks
D4
M Reg FORD TRANSIT 100, SWB, Diesel, Manual, Low Roof, 2.5, Non Turbo
d4funky1
Postby Gunslinger » Mon May 08, 2006 4:14 pm
i have a mk2 door i can weigh if no one else helps you out, it will give you a ballpark figure to work with, for collection and delivery i tend to use this lot :)
http://www.parceluk.co.uk/index.php
just had a mk2 front door collected/delivered for about £30 that was weighed up and declared at 30kgs
have a play with their online size/price thing
Gunslinger
Postby d4funky1 » Mon May 08, 2006 4:47 pm
Thanks for that Gunslinger.
If you could weigh that door for me for ball park it would be appreciated.
d4funky1
Postby Gunslinger » Mon May 08, 2006 5:09 pm
ok,
drivers side rear door totally bare = 10kg
Passenger side rear door with glass, hinges and all fittings = 18kg
Gunslinger
Postby transitgeoff » Mon May 08, 2006 6:48 pm
i do mail order a lot,and from my experience if you havent an account with someone and use it regular, with these items they will do what they call "cube it" because of the size and its low weight i dont know how they work it out but they will probably cube a door to about 50kg, then charge accordingly, probably be cheeper to go to a ford dealer and buy new doors :roll:
transitgeoff
Postby Gunslinger » Mon May 08, 2006 7:10 pm
yes they do something like that dependant on sizes then they work by weight, but the good thinga about that site i use, is distance is not considered, and if you can get them to collect from business and deliver to business addresses then its cheaper still
Gunslinger
Postby d4funky1 » Mon May 08, 2006 8:32 pm
Hmmmmm?
Best thing for me to give them a call tomorrow.
transitgeoff i see that you dismantle do you happen to have a set of rear doors for a low top 1991 transit?
d4funky1
Postby Gunslinger » Mon May 08, 2006 10:17 pm
i just did (in cm's) 200x20x100 at 50kg and as geoff said they "cube'd" it at 67kg, that was a guestimate at the 2 doors packed together and it came to £42 and some change, so worth getting your seller to tell you dimensions of both wrapped together and and then weighed that way you can get a more acurate figure, because the sizes are important and can save you some dosh
Gunslinger
