timing belt -fuel pump relation
Postby koondaholaa » Sun Dec 20, 2009 9:53 pm
is it possible that faulty fuel pump will break the timing belt while you drive ?
i have gotten new ful pump from an 1997 banana engine for my 1993 banana engine
not shure though if the numbers match -the van is 300 km way from here
is there step by step to set the timing after a switch the fuel pump
any suggestion as to what tp look for ??
thanks Kamil
koondaholaa
Re: timing belt -fuel pump relation
Postby GBBiker » Sun Dec 20, 2009 10:13 pm
You should fit a new timing belt seeing as you will need to remove the old one. I would not recommend re-using the original one :!:
Replacing the belt has been covered plenty of times on here, just do a search for a step by step guide... :wink:
GBBiker
Wrong Again!
Postby koondaholaa » Mon Dec 21, 2009 1:46 am
yes you know the timing belt snapped for the second time since the (what i suspect) fuel pump started malfunctioning
its cutting of at high speed up hill only from 4 gear up
i have timming belt but wanted to know more about the fuel pump
is it possible the timing belt snapped twice because of other issue
thanks kamil
koondaholaa
Postby chris_gilly » Mon Dec 21, 2009 11:28 am
tensioners all ok? spinning freely?
belt to tight?
they could cause the belt to snap!
chris_gilly
Postby Jim Archer » Mon Dec 21, 2009 8:04 pm
Pulley teeth pitch/size changed at some point. It's pretty obvious as the belts don't fit properly, but could be forced to fit if you don't notice.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby MinorMatt » Mon Dec 21, 2009 8:08 pm
'97 pump will fit a '93 engine... BUT '97 is a changeover year for the injection system. You may or may not have the right injectors to go with it!
