Fitting a replacement heater resistor
Postby Trojan » Wed Dec 23, 2009 5:40 pm
Hi,
My fan works on only setting 3, so gathered it would be the heator resistor. Have ordered one off the bay, which arrived today. Went to fit it, only to find that the old (rather burnt out looking) one only has two spade connectors on it, and was mounted in the centre of the engine, rivitted just to the O/S side, near the bulkhead - the new one has three connectors. The van is a LWB 190 Mk4 (1993).
Have they sent me the wrong part, or have I missed something glaringly obvious?
Some people say I am stupid... I never realised I was that clever.
Trojan
Re: Fitting a replacement heater resistor
Postby MinorMatt » Wed Dec 23, 2009 5:48 pm
I think thats the dip/dim resistor you have found...
Postby MrMPuk » Wed Dec 23, 2009 6:13 pm
MinorMatt wrote:I think thats the dip/dim resistor you have found...
Sounds like it.
Postby Trojan » Wed Dec 23, 2009 6:22 pm
Damn! Well, I better have another look tomorrow in the daylight. I guess it's more hidden than I thought - any suggestions on an easy way to find it?
Trojan
Postby MrMPuk » Wed Dec 23, 2009 6:28 pm
Have you seen the thread in the how to section?
Postby Trojan » Wed Dec 23, 2009 6:36 pm
MrMPuk wrote:Have you seen the thread in the how to section?
I must be really daft, as I cannot find a thread on it in the "how to" section. :cry:
Trojan
Postby MrMPuk » Wed Dec 23, 2009 6:38 pm
My bad, useful info section.
viewtopic.php?f=31&t=12288
Might also be worth trying the search function, lots of people have done the job in the past.
Postby Trojan » Wed Dec 23, 2009 6:56 pm
MrMPuk wrote:My bad, useful info section.
Ah, got it! Now I have figured out why it's impossible to find - the old one is missing! Found a three pin plug and wire that goes to nothing near the drivers headlight, but the pins have corroded badly, and the resistor is missing. Will have a go at clearing out the old plug to fit the new resistor in the daylight tomorrow. Thanks everyone, and especially MrMPuk - your patience is appreciated.
Trojan
Postby MrMPuk » Wed Dec 23, 2009 7:01 pm
Trojan wrote:Thanks everyone, and especially MrMPuk - your patience is appreciated.
Now there's something you don't hear everyday. :lol: :lol:
Postby dieseldel » Thu Dec 24, 2009 12:11 am
hi
connector will be corroded beyond help, headlamp bulb connector is same, if you chop one off a scrapper solder to existing wiring shrink wrap to keep out moisture bung on new resister pop rivet back to original position , job done
it was like that before i touched it !!
dieseldel
Postby Trojan » Thu Dec 24, 2009 12:30 am
dieseldel wrote:hi
Ah, cheers. I was kinda hoping that it would be repairable, but I fear your right. I may just crimp on some new spade connectors, and fit it that way - should remove the risk of moisture getting into the old wiring.
Trojan
Postby GBBiker » Thu Dec 24, 2009 12:03 pm
Fit insulated crimp-on spade terminals, much easier.
I also relocated my resistor to prevent future problems. Basically made up an alu bracket and bolted it to the battery tray. It's much more protected there and there's plenty of the loom to play with.
GBBiker
Wrong Again!
Postby Trojan » Thu Dec 24, 2009 2:48 pm
GBBiker wrote:Fit insulated crimp-on spade terminals, much easier.
Done and done :)
Also traced the second battery fault, cleaned and replaced the rear flooring now I have a working heater, blowing on all three settings! (Well, cannot get off my own driveway so may as well work on the van instead!)
Trojan
