PATS system from a Turbo diesel transit
Postby paul_elwell » Fri Dec 25, 2009 2:03 pm
Anyone help?
Will need I belive
Key
ECU
PATS module from behind glovebox
Cheers
paul_elwell
Re: PATS system from a Turbo diesel transit
Postby psv-hgv-flt » Fri Dec 25, 2009 8:24 pm
MORE INFO REQ,D. reg, year, bhp, mk5.?? and what is wrong.?? :wink:
psv-hgv-flt
Postby paul_elwell » Sat Dec 26, 2009 10:57 am
Right,
Its an R reg recovery truck that was a none turbo
Engine has been put in bin, and a turbo one from I belive a V reg found
All fitted, but didn't get PATS box from behind the glove box
Pump will not run, its a lucus one.
Any advice?
paul_elwell
Postby psv-hgv-flt » Sat Dec 26, 2009 2:20 pm
paul_elwell wrote:Right,
Any advice?
you mean ecu, and has it still got the epic pump on or has it been changed to a manual.??
psv-hgv-flt
Postby paul_elwell » Sat Dec 26, 2009 10:39 pm
You've lost me on the pump mate, can you explain?
paul_elwell
Postby psv-hgv-flt » Sun Dec 27, 2009 12:11 am
paul_elwell wrote:You've lost me on the pump mate, can you explain?
electronic (injector) pump. (with wires to it)
looks like this.
:wink:
psv-hgv-flt
Postby paul_elwell » Sun Dec 27, 2009 11:50 am
Looks as complex as that yes. Lucus pump. Loads of wires to it.
Cheers for your help so far, perhaps this thread should be moved?
paul_elwell
Postby Altransit » Sun Dec 27, 2009 12:26 pm
Have you fitted the ECU and wiring loom that controls that pump :?:
Postby psv-hgv-flt » Sun Dec 27, 2009 2:29 pm
Altransit wrote:Have you fitted the ECU and wiring loom that controls that pump :?:
it would seem he has not to me,..?? altransit
psv-hgv-flt
Postby captain hook » Sun Dec 27, 2009 3:49 pm
Fit a 145 or 146 pump and turn up the fueling.... :lol:
That's your only way forward :)
captain hook
Postby paul_elwell » Sun Dec 27, 2009 8:06 pm
Yes have fitted loom correct, all plugged in as far as I know
paul_elwell
Postby ake » Sun Dec 27, 2009 9:11 pm
You cannot bypass the immobiliser on an epic transit, so you need the Pats module, Key, Looms, Ecu, Key sense ring from the donor vehicle, also have you checked all the fuses
Postby paul_elwell » Sun Dec 27, 2009 9:22 pm
No worries, didnt think you could hence this thread was originaly a wanted ad!
Anyone got these bits?
paul_elwell
Postby ake » Sun Dec 27, 2009 9:34 pm
Perhaps an ad in Transit parts wanted would work better :?:
