tdb9 wrote:I had a wheel bearing go a few weeks back on the front left wheel. Mine was noisy in a straight line and quiet when steering. An easy check would be to jack the wheel just off the floor and feel for any loose play in the bearing.
Rob
vanfox wrote:The mot expires in april however i was thinking of just taking it to a garage for a mot and see what they say,
Agh! The last thing you wanna do is move the MOT to the middle of WINTER. Mine's in March, wish it was in May!
MinorMatt wrote:My bearing book lists 2 different wheel bearings dependant on the model (ie. 5 stud or 6 stud axle!)
crazystevie wrote: Well it drives ok then as you acelerate away you get to 38mph and i start to get a whining noise as you go faster the noise gets louder,
Also when turning right i get a loud squeaking sound from the front left hand side,
crazystevie wrote:MinorMatt wrote:My bearing book lists 2 different wheel bearings dependant on the model (ie. 5 stud or 6 stud axle!)
I would be interested to hear more:
Mine is a 1998 swb 5 stud, tourneo, do you have a part number etc, as my mechanic seems to be strugling with this one, i apreciate your help.
