I have just noticed that the engine mountings are difrent, I assume this means I use the old ones as they new ones dont seem to be the right angle to mate up with the cross member. Is this the case? I would rather use the later mounts if possible.
Are there any other difrences I should know about?
I have the later gearbox but as the 'box fitted is in good condition I would perfer to continue using it, if there are no compatibility issues.
