power loss
power loss
Postby stuartwilkins1 » Sun Jan 03, 2010 4:51 pm
Hi, I have an s reg transit. I have noticed that once the engine is warm there is a sudden power loss which usually happens in 5th gear after being in it for a while. Feels like it loses some compression or something and it has a different sound to the engine but im no mechanic. Sometimes a drop in gear and a blast in 4th, which is usually essential, sorts it for a while. I was told when i bought it that one of the injectors needs bleeding every so often, is this related ? If not does anyone have any ideas and anyone know a cure for the injector or is it a case of buying a new one. Ths probably sounds thick to some people but like I said Im far from a mechanic. Thanks in advance.
[color=#0000BF]Wilkinstall Plumbing & Home Improvements-West Midlands Stuart 07708731610.[/color]
stuartwilkins1
Re: power loss
Postby Steve B » Sun Jan 03, 2010 5:09 pm
have a search for `leak off mod` that should sort it out
Steve B
Re: power loss
Postby stuartwilkins1 » Sun Jan 03, 2010 9:22 pm
Thanks steve, sounds like thats the exact problem that I have got. Will try it when I get chance, thanks again.
stuartwilkins1
Re: power loss
Postby Steve B » Mon Jan 04, 2010 3:16 am
your welcome, but its only things that I learnt from this forum, the thanks should go to the clever bods on here!
Steve B
