draining battery
draining battery
Postby a13z » Sun Jan 03, 2010 7:07 pm
hi again all.
my t reg transit wont start. i tested the battery and its fine some thing seems to drain the battery. just wondering how would i find out what it is thanks
a13z
Re: draining battery
Postby Gaz 270 » Sun Jan 03, 2010 7:14 pm
remove negative battery terminal and connect in series an ammeter or even a bulb pref head light bulb , with all consumers turned off ( as it would be parked) the intensity of the bulb will tell you how much off a drain there is , you can then begin to remove fuses one at a time when the light goes out you will know which circuit has the drain and you can investigate further
keep it real
Gaz 270
Postby GBBiker » Sun Jan 03, 2010 7:16 pm
Put a multimeter (current setting) across the battery (-) terminal and the (-) lead (disconnect it first) and pull fuses one by one until the drain stops. That will tell you which circuit the drain is on
If pulling fuses doesn't locate the problem, it will most likely be the diode pack on the alternator. In this case, a new alternator is quicker and easier.
GBBiker
Wrong Again!
Postby MrMPuk » Sun Jan 03, 2010 7:21 pm
Maybe if you replied to one of your other many threads on the subject that you've started we'd know what you've already tried.
I'll link you to one that has the the info you need that you never replied back to.
viewtopic.php?f=4&t=54900
