94' 2.5 non turbo, non start
Postby technixcars » Mon Jan 04, 2010 12:03 pm
hello people, ive a 94 plate, 2.5 non turbo non start. has been stood up in the cold over xmas period, was running fine prior to this. went to start this morning and it just cranks over. have tried cracking diesel pipes off, am getting desiel up there, still no go. have got the hairdryer out, trying to warm everything up but still no go, doesnt sound like timing belt has slipped?? any suggestions please?? thanks.
technixcars
Re: 94' 2.5 non turbo, non start
Postby MrMPuk » Mon Jan 04, 2010 12:06 pm
Get someone to give you a jump start.
Postby technixcars » Mon Jan 04, 2010 12:12 pm
battery is fine mate, also got it on a jump starter, turns over more than good enough.
technixcars
Postby GBBiker » Mon Jan 04, 2010 1:19 pm
Can you get someone to bump/push start?
2ng gear, foot pressed down on clutch with ignition on. When you get a fair speed up, dump the clutch and floor the gas.
GBBiker
Wrong Again!
Postby manandvan » Mon Jan 04, 2010 3:15 pm
bigger hair dryer :lol:
manandvan
Postby ake » Mon Jan 04, 2010 3:19 pm
When did it last get a fuel filter :?: Cos if its an old one the water in the bottom of it will have frozen, Pull of oil cap and look in whilst someone turns it over and look for valve gear moving to see if belt is broken
