bugger.
realised ive not used the work van for 4 weeks over christmas, dashed home. same story. double bugger. not enough glycol in either.
got both thawed out with fan heaters and buckets of hot water. not attempted to run them yet, no loose coreplugs or apparent leaks. just hope they dont make like fire pumps when i do
thankfully the red van is ok. check your antifreeze people, even if you're sure its ok. i was.....
