heater fan
heater fan
Postby fester333 » Wed Jan 13, 2010 7:39 pm
greetings out there
need some advice please
got a mk 5 lwb love it to bits but this morning had the heater on and as working fine till i had a horrible sqeaking noise comeing from under the dash the noise stopped if i turned it don to 1 on the switch. left it till this afternoon and then checked again to see if i could locate noise and had the fan running 4 about 30 secs when i suddenly stopped and then realised that i now had no heating so am assuming fan has burnt out
have searched site cos cant locate fan so could someone tell where to locate it and am i right in my findings that the fan has burnt out
regards fester
sunny dorset
fester333
Re: heater fan
Postby sibyt » Wed Jan 13, 2010 7:46 pm
what a coincidence ive just had the same problem myself the bearing has gone in mine causing it to jam and blow the fuse ive just finished taking it out.
the motor is behind the radio and is quite dificult to remove
after scratching my head for an hour i searched on here and found a guide on how to remove it and it only took 5 mins
sibyt
Re: heater fan
Postby fester333 » Wed Jan 13, 2010 7:49 pm
can i ask under what heading did you find the info cos i did a search and didnt come up with anything
fester333
Re: heater fan
Postby sibyt » Wed Jan 13, 2010 7:55 pm
viewtopic.php?f=4&t=44233&hilit=remove+blower+motor
its near the botom of the page in the link above hope this helps
sibyt
