AndyJ2506 wrote:Hi guys
My van came with one of the little cab heaters found on the BT vans so could somebody please tell me how these work as my van takes a good 15 miles to warm up and its not fun. i can get it and the fan in the cab to run but it never gets hot. Also my temp gauge doesn't work so would this contribute to it not warming up very quickly
Cheers in advance
Andy
davev6newman wrote:As far as i know these heaters are simular to the eberspacher heater, they run on diesel and work independently from the normal heater. You can even set them to come on early so as to warm the van up before you get in it in the mornings.
How they work i do not know tho.
ake wrote:davev6newman wrote:As far as i know these heaters are simular to the eberspacher heater, they run on diesel and work independently from the normal heater. You can even set them to come on early so as to warm the van up before you get in it in the mornings.
They are similar to an Eberspacher because they ARE an Eberspacher
MinorMatt wrote:are you pressing the button and then starting straight up? If so it will do sod all. Switch it on about 15min before starting the engine, it will preheat the coolant to about 80 degrees...
The other thing is to check its still plumbed in - ie its got the water pipes connected
AndyJ2506 wrote:MinorMatt wrote:are you pressing the button and then starting straight up? If so it will do sod all. Switch it on about 15min before starting the engine, it will preheat the coolant to about 80 degrees...
Cheers for the replys. I'm pretty sure itsstill plumbed in asall the pipes still run into the engine bay. I left it running for about 35 mins and it was still blowing cold air. It seems to be running ok itsjust not getting warm
Does anyone know anybody who servicesthem around Essex area
