battery light on
battery light on
Postby geminivehicles » Sat Jan 16, 2010 2:06 pm
as a bove 1999 di batt light comes on when first starts on a morning for a few seconds then goes out happend twice 2 days in arow then this morning had to jump start now starts fine but started fine right through the cold spell any ideas if it could be battor alternatior thanks in advance paul :?
1999 100 MK5 LWB CUSTOM SHR aux batt,e/w,c/l,tv,dvd,xbox,cctv
transit mk5 custom with a evil twist (painted at last)
geminivehicles
Re: battery light on
Postby dodgy01 » Sat Jan 16, 2010 3:05 pm
yep the alternator is not pushing out enough just a replacement it will be fine
dodgy01
Postby Trojan » Sun Jan 17, 2010 2:52 am
If you are saying that the battery light stays on when you start, but goes off when you drive it, then that's normal, mine does that as well. Quite often in this weather, we use just about every item of electrics in the van. If it's struggling to start from time to time though, it may be the battery is getting weak, or you are not allowing it to recharge the battery (i.e. lots of short runs).
If, however, I have misunderstood your comment, and the light stays on all the time, then yes, it's likely to be the alternator that needs replacing, if you have checked over the wiring.
Some people say I am stupid... I never realised I was that clever.
Trojan
Postby geminivehicles » Sun Jan 17, 2010 8:50 am
the light stays on for about 1 min then goes out however if you rev it it still stays on for the same time it has never done this before and i have owned the foe a little over six mth many thanks paul
geminivehicles
Postby dodgy01 » Sun Jan 17, 2010 10:39 am
the alternator is not putting out enough just put a volt meter accross the battery with all the electrics on and the engine running it should be between 13 and 14.5v really
dodgy01
Postby geminivehicles » Sun Jan 17, 2010 7:19 pm
sorted only putting out 11.8 volts thanks to everyone
geminivehicles
Postby dodgy01 » Sun Jan 17, 2010 8:18 pm
as above then im afraid its bu@@ered
dodgy01
