axle ratios
axle ratios
Postby djuwenda » Mon Jan 18, 2010 2:24 pm
Hi All...
I was reading the for sale board and came upon the following:
Cheeky-monkey wrote:wot do you mean ?
Andyg wrote:
He means that you have the desirable, and much sought after 4.11 rear axle ratio :wink:
They are sought after, as they give a higher cruising speed, than the higher ratio axles fitted to the majority of Transits :D
I am on the market for a transit for the second time. The first time I ended up buying a citroen relay 1.9 which was pretty good bar the obvious underpowered plant.
So thats gone and I am now lurking on the for sale board again :)
Question is, how do you guys determine a van's axle ratio?
djuwenda
Re: axle ratios
Postby MrMPuk » Mon Jan 18, 2010 2:37 pm
djuwenda wrote:Question is, how do you guys determine a van's axle ratio?
viewtopic.php?f=31&t=10363 or from the tag on the axle or from the Reg\VIN on Ford's ETIS Site.
Re: axle ratios
Postby djuwenda » Fri Jan 22, 2010 9:23 am
Ah ok... I am quite tempted by what looks like a mk5 1999-T reg
its an 80swb semi high roof with twin SLD's
reg is T625KGA.
Anything I should keep an eye out for?
The twin LSD are useful to me as I spend most of my time on the continent, and I want the 2.5d as it seems to be so over engineered.
djuwenda
Re: axle ratios
Postby MrMPuk » Fri Jan 22, 2010 2:32 pm
Transit 95, Diesel 2.5 (76PS), Diamond White 73
VIN Number: WF0LXXBDVLWR75623
Registration Number: T625KGA
Registration Date: 21.05.1999
Registration Country: GB
Primary Features
Build Date: 16.10.1998
Vehicle Line: Transit 95
Cab Style: Regular Cargo Van
Series: 80 Series
Engine: Diesel 2.5 (76PS)
Transmission: 5-Speed Manual - MT75
Drive: RHD RWD
Axle Ratio: 4.56
Emission: 97 EC LDT Requirements
Territory: (+)"GB"
Paint: Diamond White 73
Interior Fabric: Windrush G-C
Re: axle ratios
Postby djuwenda » Fri Jan 22, 2010 3:32 pm
thanks you very much for that!
djuwenda
