I have a starting problem with my 89 Diesel 2.5 (not banana).
Since I got it about a year ago it had always started with no problem on first turn (apart from when I had a blockage in the fuel line from the tank).
Last week - after lying up for a few weeks over xmas and the following cold spell - it started as usual without a problem, but cut out after a couple of minutes.
I have not been able to get it started since, although fuel is getting through to the injectors (I took a feed pipe off one of the injectors and when I crank the engine fuel does come out of it).
Can anyone suggest what might be preventing it starting or where I start looking for the problem.
