motorwise wrote:go to your local transit breaker and buy a dash panel from an early smiley with the smaller radio - this has a storage tray underneath the radio which can be taken out to fit a second radio - all you'll need to do is install the fitting cages that came with the radios into the holes
hope it helps
MarkM wrote:Now if you decide to go some other route and want to change your dash to a single din with a 2nd Din hole below (this would be a better option for fitting both pieces of gear since you have two identical slots and no paper/document slot underneath)
MarkM wrote:motorwise wrote:go to your local transit breaker and buy a dash panel from an early smiley with the smaller radio - this has a storage tray underneath the radio which can be taken out to fit a second radio - all you'll need to do is install the fitting cages that came with the radios into the holes
hope it helps
I already said thatMarkM wrote:Now if you decide to go some other route and want to change your dash to a single din with a 2nd Din hole below (this would be a better option for fitting both pieces of gear since you have two identical slots and no paper/document slot underneath)
